Make: Nissan
Model: Skyline R33 GTST
Milage: 115,000
Transmission: Manual
Colour: Maroon
Currently registered? Yes - NSW Rego
Full insurance.
Regular service from Trojan, Autotech Canberra and Overdrive performance Braidwood
Price: $14,000 ono
Contact: J on 0412 097 311 or PM me.
Reason for selling: Moving to the USA. (selling everything).
Comments / Modifications:
Below is a list of all the modifications that have been done to the car, making well over 350rwkws. If there are any questions please feel free to pm me or give me a call on my mobile. I'll do my best to answer them but I'm no grease monkey.
Pics are already on the forum from when I bought it early last year.
1995 dec built r33 gtst, 115000kms,
ECU/Engine/Exhaust
350rwkws
APEXi power FC with H/C
Garrett T04Z 800HP twin ball bearing turbo.
Turbo smart 45mm waste gate with dump to atmosphere.
6 boost high flow exhaust manafold
Trust type-R BOV
Tomei 264 in/ex camshafts
Tomei 280L/H Fuel pump
NISMO 550cc injectors (This is what he was told when he purchased the car, but when the car was dyno'd the tunner said they were more likely 660cc)
NISMO Fuel regulator
NISMO Oil cap
Fujitsubo 3.1/2in exhaust with high flow cat
3 1/2in custom dump
Greddy Exhaust Adjustable Cam Gear.
Greddy Engine Oil Cooler
Greddy Oil Catch Can
Greddy Intake Plenum
Greddy Profec B boost controller
Port and polished RB25DET head
Q45 Throttle Boddy 90mm
Q45 AFM 90mm
Suction and cooling
APEXI power Intake
TRUST V-SPL Intercooler kit
Drivetrain
C's Quickshift kit
OS Giken Twin Plate Cllutch with lighten Flywheel
NISMO Oversixe slave clutch cylinder
Handling
Tomi Brake Master Cylinder Brace
FET Strut Tower Brace(f)
CUSCO Strut Tower Braces ®
DBA Drill and Slotted Roters (F&R)
Bilstein Strut and Whinelint Spring
Section HICAPS Lock Bar
Whiteline Handling Pack
Whiteline Urethene suspension bushes (F&R)
Whiteline anti-roll bars (F&R)
Interior
APEXI EL Mechanical Boost Gauge
APEXI RSV with DIY shift light
MOMO Steering Wheel
MOMO Gear Knob
Pioneer MP3 Head Unit with Pioneer Speakers/Spliters (F&R)
New Clarion AMP
Alpine 12'' sub woofer.
Exterior
R33 GT-R Front Bar with indicators
R33 GT-R style Rear Wing
R33 GT-R Style side skirt
3 Point immobiliser Alarm
Hi All.
Thanks for the interest...all PMs replied to.
Forgot to mention it still has 10 months rego on it.
Or nearest offer - I'd like to get the car sold asap - overseas awaits.
Cheers.
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
Guest
