Firstly, I love this car and the only reason im selling it is to buy a GTR. I've owned this car for three years and have spared no expense. Not daily driven and never seen a race track. It has driven 4000km over the last two years. This car has been religiously maintained and serviced with only genuine parts. Timing belt, Waterpump, idle pulleys all changed at 80,000km. Serviced every three months driven or not. The car is in excellent condition and built to be streetable and reliable. It has never been defected and has never missed a beat. I believe it's one of the better R33's on the roads. If the car does not sell i will be more than happy to keep it as it's an awesome car. All modification to the car have been quality parts. I dont see the point in cutting corners. A very stealth low mount gt35r and a very conservative low knock tune produces 304rwkw. Drives like a normal car off boost with great economy and rips your balls off when you hit the go pedal. Exterior and Interior are immaculate with no blue lights, no guages, built with no bullshit in mind.
If your after a car with no bullshit, Money spent and heaps of potential then i believe this car is it.
97 S2 R33 Type M GTS-T
88,000km
Information:
Standard Internals, Standard Cams/Gears
GT35R (1000km old)
Dmax Exhaust manifold
Speedflow/braided lines
My own Fabricated Dump pipe
Power FC
Nismo 555cc Injectors (3000km old)
Nismo Fuel Pump (3000km old)
Z32 AFM
Single Plate button Clutch (3000km old)
Tien HR coilovers
Work VS-XX 18 x 9 +1 (215/40) FRONT 18 x 10 +11 (225/40) (70% tread all round)
Hicas Lock bar
Greenstuff pads (brandnew)
No gay guages, No gay kits, simple layout. No Bullshit
304rwkw @ 17psi (Tuned by Willall and quite conservative)
I like to think that it's one of the better examples of a 33. Unlike majority of the gayed up ones out there.
$20,000 Firm. If it does not sell for $20,000 it's not selling.
0404804593
MEMBERS RIDES: Ryan's R33
https://www.sau.com.au/forums/topic/273762-r33-gts-t-sa/
Thanks mate, yeah definetly agree...and it's funny you say that because i bought black hose for that exact reason just never got around to doing it.
Car has been sitting in my workshop for the last month needing someone to enjoy it.
https://www.sau.com.au/forums/topic/273762-r33-gts-t-sa/#findComment-4662942
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
