The brakes sticky is getting a bit long and posts lost.
I've found these Brembo brakes and am fairly sure I've worked it out right and they will go on my M35 (i believe they've come off an ARX) but any help appreciated.
Details:
bremboF50 & Lotus caliper? 370×30mm&340×27mm (F12mmR10mm残) × 1 cars caliper Stagea M35 KIT (Status mount) × 1 370 × 30mm & 340 × 27mm 2 piece rotors
cheers
https://www.sau.com.au/forums/topic/273773-will-these-brembos-fit-on-the-m35/
Is this a yahoo item?
i guess your going to be perfect you will need wheels 17 and upwards, but the stagea has them right? (i've not even looked at sizes)
The f50 kit on the gtr uses new caliper mounts, the things on the left in the photo which i am guessing will be included..
Details:
cheers
Yes.
But you will need to have 18's (minimum) to clear the calipers.
RS 17's won't clear.
depending on how the 17's offset you will be able to fit 17's for sure..
i only have 17x9.5 on the gtr and there is plenty of space
and this is with a new rotor/hat setup i had to get made up here as sourcing new rotors from anywhere was difficult
there is no chance fitting 370mm rotors and F50s under 17inch wheels. yours look like 355mm max or even 343mm maybe?
Ahh shit i just noticed he said 370mm that is alot larger than what i have!
i did however fit some pretty flat design wheels to the gtr also, volk gtu and also the r34 gtr wheels and also some old styled advans the volks however were a close fit.
should just buy these, have to run 19" wheels minimum by the looks but :(
http://page4.auctions.yahoo.co.jp/jp/auction/d94092768
I'm guessing thats the calipers hes found.
not a bad price so far, good luck with them if you get!
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
