Qld- Heaps Of Good Stuff Suit R33
hey everyone.
Finally decided to give it all up and sell up all my bits and pieces that i've been hording for ages now.
Any questions or offers then just ask.
All parts are located in brisbane on the northside.
XHP Speedster Wheels in chrome 5 stud 19 x 8.5" +35 all round look and sit great on my 33 just dont like the bling look. few gutter scratch marks here and there but nothing nasty. have federal 595 tyres fronts 80% rears 70% but camber worn. $1500
rb25det Motor, was built 10 000kms ago with balanced stock internals ACL FORGED pistons 8:5:1 compression (for higher boost) stock head etc. comes with forward facing plenum (greddy copy polished) high mount turbo manifold (xs power) and hypergear tr43 turbo with 0.5front and .58 rear and 3inch dump pipe. $2000 ono
Wolf 3d Version 4 plus with hand controller and rb25det loom. has a very safe tune to suit above mentioned motor. made 190rwkws on 14psi $1250
R32 5 speed box in great condition $300
Series 2 rb25det G/BOX, 101 000kms have been done on this box (have cluster to prove) $1300
Bosch 040 intank fuel pump (genuine) Brand new. $150
R33 gtst front disc rotors and calipers, good cond. come with pads aswell unknow brand. $300
R33 gtst dash from series 2 $100
R33 gtst cluster manual from series 2 (reads 101 500kms) works perfect $80
33 gtst alternator $50
33 gtst starter motor $50
33 gtst Steering rack good nick $100
33 gtst front suspension arms and uprights with stub axles and stock shocks and springs $100
33 brake booster $50
33 steering wheel (airbag still good not deployed) it is the whole steering colomn aswell $150
33 power steering pump and resoviour good cond. $50
Fet type r turbo timer $70
Razo turbo timer $90
R33 Lowered king springs front and rear $50
R33 radiator good condition $100
R33 series 1 coilpacks, removed due to fitting splitfires, worked fine when removed. $80
OBX rising rate fuel pressure reg. $80
Genuine hks boost guage in bar not psi bout 40mm the guage is quite small was fitted were the clock on the dash is in my 33. black face with red numbers. $50
33 smic series 1 $40
All items are pick up only. SORRY
have had too many dramas with postage and just dont have the time to piss around with it.
PICS WILL FOLLOW WITH INTEREST as there is a few things here although will put up picks of the engine and so on shortly.
Located north side of BRISBANE
pls pm or sms 0430 218 339. justin....
 Share
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
