hey i have this motor was going to put in the new rig but dont have the $$ to pay for rig so need to sell it.
if some one is keen ill sell it if not will just keep so not really fussed.
Rb30 s11 Bottom end 70,000kms. Un opened.
Rb25 s2 Head Fresh Mill clean.
VCT disabled and running RB20 Inlet cam.
VCT oil gallery welded Up.
-16 Oil return from back of head.
Standard Sump with 1" hose fitting welded on.
ACL 1.3mm Metal Head gasket.
Rb25 s2 Oil Pump, New gears and seal
Rb25 s2 Nissan Water Pump
Rb25 s2 Nissan Thermostat
New Timing Belt and Tensioners.
Top Tensioner Relocated to Above water pump.
Rb25DET s2 Inlet manifold complete with injectors and loom.
Repco Filter
rb25det Knock Sensors
rb25det Oil Press sensor.
Rb25det Alt.
Custom head return on exhaust side to turbo oil drain.
Thats It have Cancelled all heater hoses also.
All thats Needed is Turbo/Manifold/Coil packs/CAS/loom/ECU and its sorted.
$1600 ono.
located in S.A WINGFIELD.
PICKUP ONLY.
cheers ben
0416 640 060
https://www.sau.com.au/forums/topic/273818-eoi-rb2530-cheap-spec-build/
No, basically it would be a cheaper and more torquey alternative to an rb25....
I am well aware of that I have a 25/30 in my car. Unopened rb30's are worth less than $150. Where is the value in what he is selling being retained as rb25 heads have been going for $400-$500 recently.
Here we go...
Just cos it dosent have brand name forgies and machine work from miltons your going to shit on it.
Some people cant afford all the bells and whistles. I own a workshop and f**k i dont have a car.
I built this motor to put in my own car when i could afford one, i was not planning on putting a GT4082 on the thing with 1000cc Inj the as for the obvious reasons that u have clearly stated.(un-opened rb30 )
This motor will handle a easy 250rwkw and torquy as shit all day everyday for a long time.
Im not trying to sell it as some bullshit built motor hence the tittle.
Please Keep you comments to yourself.
For every one else info this is the money thats been spent.
NOT TO MENTION THE LABOUR ENVOLVED...
Complete RB30 S2 70,000kms $200
Rb25det head $300
Head Mill $75
-16 Fitting and welded to head $75
Head pressure checked $75
ACL Metal Head gasket $220
New water Pump $80
New thermostat $35
New Tensioner/Idler $150
New timing Belt $30
New Cam and Oil pump Seals $15
Hoses and Earls Fittings $200
Oil Filter $10
Any serious inquires please feel free to call 9-5: 0416 640 060
cheers ben
Edited by Benny-g
Here we go...
Rb25det head $300
Head Mill $75
New water Pump $80
New thermostat $35
New timing Belt $30
Oil Filter $10
cheers ben
well put benny...
for those interested I had an almost identical set up (ie. unopened RB30 with 25 head) with a GT35r in a commodore which made 300KW at the wheels. I put it together around 5 years ago around the time GT35R's were released, it was safey tuned and with a new owner these days it is still making the same power and still reliable. Very cheap and reliable way to make a s#$tload of torque and power.
cheers
Lee
Here we go...
Rb25det head $300
Head Mill $75
New water Pump $80
New thermostat $35
New timing Belt $30
Oil Filter $10
cheers ben
well said dude i have a head and rb30 sitting here maybe he could come put it together for free as i cant be both ha ha
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
    • Try fabricating something like this and install it under the pedals? Not sure if it's legal or not....
    • Even though I have some pretty good (brand) ratchet ringies, I avoid using them to break open tight bolts. A broken ratchet is very annoying.
