I've only heard good things about JUN. In fact I've heard of people making their own home-made cam gears and re-labelling them as JUN, because they look kind of similar. ie, not bright pink and green like HKS which would obviously not be the same as a modified factory one.
thanx JimX, thats 1 positive one
im building from the bottom end up
firstly nismo bearings, and a JUN oil pump and baffle etc... then just go upwards from there keeping the block and drivetrain stonger than needed at any point until a t51r spl goes on .... mmmmmm
thats a while away yet tho
keep the comments flowing guys
Every Jun cam we have had has come in plastic water pipe wrapping and no spec sheets so we may have been getting ripped of.WE got lots of different timing specs from the supplier making dial in real hard and the Springs had very different seat pressures even with the right installed hights, we have replaced all 4 sets with other brands with good results.Please don't ask were we got them from but it makes you not want to not try again.Make sure you get what you pay for and a garranty.
we used jun camshafts in a race car and broke through the hardening after one race went back to dealer and was told it was an oil feed problem checked feed put in new cam shaft and failed before we finished dyno runs,pulled cam out fitted australian cam shaft and have never had aproblem.Had jun cams checked and was told that hardening was not finished properly and JUN dealer just said not his problem and has made no attempt to repay cost of failed cams or labor tracking down problem.i personally would recommend you spend you money on other brands that will stand behind there products.
My mates Drag SR lost its hard facing before it even raced and now has Tomei cams( these Jun cams came in water pipe also with no spec sheet but the sales man is not around any more).Yes i use adjustable gears on HKS cams with sucsses because no 2 engines are the same or reconditioning changes the distance between the crank and cam gears etc.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
