easily overloaded tho
say u wire in power from the ciggie lighter
then plug a GPS into the ciggie lighter can cause it to overload and blow the fuse.
They're on two different circuits. The lighter power and light power sources are different.
I had a guy come to me wanting me to wire in 8 gauges (yes 8) in his car. What I had to do was use relays to power both sides and use the spare in his fuse box for overload.
If you're only running the one gauge you'll be okay to pick it up from the lighter light circuit, even better if you used LED's to keep the current draw down.
+1 for cigerette lighter. the light uses a serperate power feed but the same earth as the power for the lighter itself.
mines been running off there faultlessly for near a year. Using an LED in my boost gauge but :bunny:
Link it off the ring around the cig lighter. That turns on with headlights
Its the top connector in the picture below;
Instructions on how to get to it is here;
http://www.skylinesaustralia.com/forums/R3...em-t204874.html
I'm also trying to find wire clips (that let you tap into power from an existing wire), but can't for the life of me find them on the Jaycar website, are they called something else?
Scotch lock quick splice connectors. You can also use T-taps.
Should have mentioned. Go to any car parts mob like Malz, or Stupid Cheap. You'll have a better chance of finding them there than at Jaycar who are more electronics oriented.
Dick Smith have some that wrap around the source wire, and provide a spade connection for the branching wire.
o cheers for the info
my friend must of linked it to the wires going to the actual ciggie lighter .. not the circle light around it.
so if i link a boost gauge to that wire it will dim it self at night?
If you use the cigarette light, it will be full brightness at night, and not light at all during the day. Though if you lightsource the climate control uses, it will be full brightness during the day and dim at night (that's if the light will work on the dim voltage whatever it be)
so if thats the case i would connect the purple dimmer wire on the guage to the climate control and the red power wire to the ign wire or something similar?
Now that I think about it, putting the dimmer wire on the climate control is a bad idea, since you would need the climate control always turned on.. I didn't think about that consequence since my CC is always on. Stock headunits have a dimmer function iirc, if you have a aftermarket headunit just look for a wire not connected (im guessing nobody keeps the dimming function with A/M decks)
you dont need the light to be on during the day?
just go straight to the cig lighter light. Easiest and most effective. Dont worry about diming and stufff. If your that worried put a variable resistor in the circuit somewhere....
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
