U guys might wanna consider changing da idle bearing and tensioner when da timing belt gets done cause u'd onli have to pay 4 labour once.....and its pretti important them to things get done....or u will b payin heapz for a rebuild if them things fail....
Got to agree with you there - as far as I'm concerned and for the cost of NSK bearings you should do the idler/tensioner bearings at 100000k's.
Don't forget guys that not all skylines have genuine k's on them - whenever I buy a car with rubber timing belt/s I change them straight away. You know what you've got then and no surprises.
I'm glad I do all this myself as I'm pretty blown away at the quoted prices!
Cheers
  • 2 months later...
My 94 R33 S1 GTS-T is coming up to 100K. Asked a few shops around SE Melbourne and they quoted me between 450-480 to do:
- oil (using castrol magnatec?!)
- filter
- timing belt
- spark plugs
I might ask other places for a price including:
- Coolant System Air Purge
- Fuel Filter
- Brake Fluid Flush & Bleed
Are the 3 things above necessary? What do ppl think about the quoted price?
personal i would go and do myself
oil filter
oil change
fuel filter
radiator fluid change (not really flushed, but same way you change the oil)
spark plugs if i knew the right size
the rest id have to try and trust a nissan dealership with
timing belt
brake bleed
power steering flush (do they do that?)
water pump
thermostat
all belts
maybe get some hoses replaced
clutch and gear box fluid
diff oil
have i missed anything??
also what does a nissan dealership do for a 100k service??
power steering flush... they can do them.. but bit fiddly. no need to really.
my GTR is nearly on 95km. i would replace all oils, ALL filters, belts if they need em. any pumps if u need them. if ur doin Tbelt. ill replace all idlers bearings and the weak bitch of an oil pump. that and do a complete fault check. that and Check and adjust tappets if u can on the GTR havent looked at it yet.
  • 9 months later...
Hi all!
I need to do 100k service and was wondering if anyone can tell me the pros/cons of getting a genuine nissan timing belt as opposed to a nismo or gates belt??? The price difference is enormous but I don't know if there is an actual physical/mechanical difference...???
Thanx...
nissan gen is a mighty find product that lasts well over 100K, so why pay more for something else that does the same job?
Timing belts dont break from excessive power or rev's... they break due to age/mechanical failure
Edited by simon-ae86
I agree... I'm just not sure if there is some sort of benefit in having an aftermarket one??? And why the hell are they so expensive - I can get gen nissan one for $60 but a nismo one is nearly $400 - WTF????? ;)
I would also recomend replacing the tensioner pulley studs aswell, i have heard of a few horror stories of peoples tensioner studs snapping and causing the valves to obviously hit the pistons, would be very pricey to fix so i will be getting mine done on my 90xxxkm service just to be safe.
this on RB engines.?
all the tensioner bolts ive pulled off are quite thick and look rather durable. not sure if RB have springs like toyotas but that tension spring needs looking at. but is part of the T-belt kit that should be replaced at the same time.
water pumps on RB common? keeping ur coolant in check, eg fresh and right type and ratio should keep it spinning longer. :)
Heres some evidence
http://www.skylinesaustralia.com/forums/in...howtopic=131579
Its also happened to a few guys on www.skylinesdownunder.com in n.z, so i will be getting mine replaced when i get the cambelt,waterpump and tensioners done just for peice of mind. Would rather spend a few bucks on new studs then having to rebuild my motor.
Ever been down to nissan to buy a genuine fuel filter lately?
Even those aftermarket ones aren't much cheaper.
my RYCO GTR fuel filter cost 40 at trade price.
and my RYCO S14a fuel filter cost 14 at trade price.
they dont look much different.? :wave:
Heres some evidence
hey buddy. wernt calling u a lier. but thanks for digging that up. was interesting. and i think ill change mine every so often too. :wave:
have a good one.
mark
  • 5 years later...
so i know this topic is old but ill figure i should ask in here rather then making a new thred....if anyone is still watching this one :/
so i took my r33 in to Xspeed in perth for a 100k service a while back and only had a budget of $1k .
their shop is constantly full of lines so safe to say they know what their doing (however rather expensive)
so the invoice i got back said the water pump was changed,
timing belt kit (the guy said that i still need a few belts done)
nissan oem coolant
and labour
i now have a list of things i need to work through, the most important of wich are:
--fan belts all u/s - require replacement but did not do due to budget constraints
--rocker cover gaskets leaking
--coolant condition poor- this one is interesting as the guy said my radiator needs to be sent away and cleaned as alot of the cooling tubes were cloged or something?
--and exhaust manifold missing 1 stud - he also said it needs to be taken off and machined flat again before putting in new studs...
now my issue is i dont know which one to do first?
does anyone have an oppinion on this or knowledge as to whats more important?
OR if any of these i can do myself with little danger of too much damage (not to experienced but always keen to give it a shot :P)
cheers if ur still reading hahah :D
  • 1 year later...
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
