Driftmob is holding another skidpan day on the 27th of this month, it’s at Oran parks skidpan, witch is about 3weeks away. The last skidpan day that they had was insane. There was heaps of different cars that turned up and people of all skills. They also had instructors who you could run shotgun with in there cars or they were jumping in your car as passenger to help you out. There will be about 3 or 4 different layouts done on the day, with also a couple of wet sessions. They had a BBQ and drinks crankin most of the day as well.
At the last skidpan day they had a eftpos machine there so you could pay and also join up to there club, they had a tow truck there in case your car broke down, (hope this happens to no one) and also a trailer of rims with tyres on them that you could borrow for a small cost, I honestly don’t remember how much they where but a fair few people did use them.
If you have always wonted to get out there and have some fun or give drifting a crack, these are the days you would wont to come to. Even if you know how to drift these days are great just to muck around, I never knew how much fun you could have on a skidpan. (thank you Andrew Hawkins). They are a very friendly bunch of guys and there is always a great atmosphere, on top of that there prices for there days are nice and cheap, these guys even recognize if you are a member of another cams affiliated car club and will give you there members rates.
Members $85
Non members $100
Get there around 8:00ish so you have time to singe on and get your car scrutineered
There will be a drivers briefing that all drivers must attend. You will be on the skidpan around 9 o’clock and the day ends at 3:30 4 o’clockish.
More info can be found on there website http://www.driftmob.com.au/forum/
Or you can call 0406669635 if you have any questions.
https://www.sau.com.au/forums/topic/273874-skidpan-day-27th-of-this-month/
Cool thanks for the info. I've got a mate who'd be interested in this, i'll pass the details on.
You need to learn how to spell though dude.. where/were which/witch their/there want/wont... Not that it really matters.. just makes your post really hard to read! :P
EVENT OPEN
ENTRIES OPEN,
THIS IS A DRIVER TRAINING EVENT
TIME TABLE
7:30AM GATES OPEN
8:00AM SCRUTINEERING
8:30AM DRIVER SIGN ON
9:00AM DRIVER BRIEFING
9:30AM START TRACK ACTIVITY
11:30AM LUNCH
4:30PM END TRACK ACTIVITY
SPECTATOR
everybody is welcome to spectate at our events entry will be a gold coin ($1or $2) per person
all gate proceeds collected will be donated to a charity
we have an associate membership package available for spectators
costs $40 you get t-shirt, sticker, membership card & a free drink at all our events
you can apply for this on the day.
SCRUTINEERING
your car will need to pass scrutineering
brakes, brake lights, seatbelts/harnesses, windscreen wipers all need to work properly
drivers seat must be secured properly all wheel nuts must be present
you will need a secondary bonnet restraint if you dont have one just bring a short rope & the
scrutineer will assist you installing it
DRIVER
to drive you will need appropriate clothing (non flamable)
your clothes must cover you from neck to wrists to ankles
closed shoes must be worn
and only helmets with the AS1698 sticker affixed can be used
COST
$60 if you want to learn to drive ( trainee)
$85 if your a member with driftmob & have a cams license
$100 if your not a member with driftmob & have a cams license
we can issue you with a cams license on the day
if you want to become a member you can apply on the day
HOW TO PAY
entrants can pay on the day but we recommend prepaying to secure a spot
at this stage we can accept cash & eftpos if you want to pay on the day
PREPAY
deposit total amount and bring your reciept with you on the day
no prepayments after wednesday 18th
ACCOUNT NAME = DRIFTMOB INC
ACCOUNT NUMBER =259589
BSB =032372
BANK =WESTPAC
just a quick run down for the day,
we are track time orientated this means we will not stop for lunch
the bbq will start at 11:30am finish 12:30pm this will give drivers an hour to get their food
only drivers are entitled to a free feed
passengers (drift trainees) will be permitted at this event but will not be permitted to drive
if you intend to be a trainee you will need to bring your own helmet & appropriate clothing in the drivers
section mentioned above
cheers.
the driftmob crew..
so its $100 for non members BUT with a cams license, if you do not have a cams license how much will it be?
hey mate an L2ns licence is $50 which lasts 12 months but you can get a day licence for $20 but if you do a few of these events a year you would be better off getting the L2ns one
so either $150 or $120 for the day
Edited by GTR180
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
