Hi guys
Just finished putting the body kit on my car but now it looks a lil werid like it needs a grill or something ?
http://i3.photobucket.com/albums/y86/ian_and1/R34/DSC00815.jpg[/img
I have seen the URAS bonnet lip and there is a guy on ebay selling the carbon one's. but if you have any idea's or can post a pic of your R34 with the lip or something would be greatly appreaciated
Thanks Ian
https://www.sau.com.au/forums/topic/273883-r34-grill/
where is the edit button :happy: thanks for that mate yeah hopefully getting indacators and stuff sorted soon with carbon boot :cool:
stock grill, dunno if im been dumb or what not any-1 got a pic :(
Edited by ian_and1
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4645439
the plastic grill that sits between the 2 vertical parts in the centre of the bumper just below the bonnet... is that what you're talking about?
How much did that bonnet set you back? CF or FG? How's the quality ?
Edit: dont mind me the retard force is strong with me ... there's no grill even on the stock bumper as per http://www.skylinesaustralia.com/forums/post-a227793-
Edited by Delta Force
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4645490
whaaaaaat? $1300 for the bonnet and the whole kit ?? Nice score there :happy: Last time I checked the bonnet alone goes for around $900
As for boot ..IMO that would look tacky, stick with the existing one :(
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4645515
Ah hotchoc lol sorry forgot about ya bud :P um few little things, side skirts were a real pain in the kent, took heaps of time to get them to semi fit but came out ok in the end, the rear bar was the biggist issue, looks like it was poped out of the mould a little early so where it says skyline it's like on a angle ? overall fitment i would give around a 7/10 and quality about a 6/10. dont get me wrong you get what you buy for but genuine is where it is at :) some more pics for you
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4652700
Hi Ian
Thks for the pm
I'm at work atm and i can't view those pics : (
I'll have a look for em once i get home
Btw, managed to score genuine Impul sides and rear bar. One's in yellow (sides) and one's in white (white) so you can imagine the length i went thru just to source em lol. Trying to look for a place for spray painting and fitting now. I'll post the pics once they r done
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4652771
Thats tops my whole impul kit was $1100 if its not perfect im going to flip! How much was fitment mate? BTW i vote lose the eye brows and use NISMO eyelids - hard to get but take a look at the SIGNAL AUTO R34 GTR and you will understand why (needs a front shot)
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4655601
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
