Hi guys
Just finished putting the body kit on my car but now it looks a lil werid like it needs a grill or something ?
http://i3.photobucket.com/albums/y86/ian_and1/R34/DSC00815.jpg[/img
I have seen the URAS bonnet lip and there is a guy on ebay selling the carbon one's. but if you have any idea's or can post a pic of your R34 with the lip or something would be greatly appreaciated
Thanks Ian
https://www.sau.com.au/forums/topic/273883-r34-grill/
where is the edit button :happy: thanks for that mate yeah hopefully getting indacators and stuff sorted soon with carbon boot :cool:
stock grill, dunno if im been dumb or what not any-1 got a pic :(
Edited by ian_and1
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4645439
the plastic grill that sits between the 2 vertical parts in the centre of the bumper just below the bonnet... is that what you're talking about?
How much did that bonnet set you back? CF or FG? How's the quality ?
Edit: dont mind me the retard force is strong with me ... there's no grill even on the stock bumper as per http://www.skylinesaustralia.com/forums/post-a227793-
Edited by Delta Force
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4645490
whaaaaaat? $1300 for the bonnet and the whole kit ?? Nice score there :happy: Last time I checked the bonnet alone goes for around $900
As for boot ..IMO that would look tacky, stick with the existing one :(
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4645515
Ah hotchoc lol sorry forgot about ya bud :P um few little things, side skirts were a real pain in the kent, took heaps of time to get them to semi fit but came out ok in the end, the rear bar was the biggist issue, looks like it was poped out of the mould a little early so where it says skyline it's like on a angle ? overall fitment i would give around a 7/10 and quality about a 6/10. dont get me wrong you get what you buy for but genuine is where it is at :) some more pics for you
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4652700
Hi Ian
Thks for the pm
I'm at work atm and i can't view those pics : (
I'll have a look for em once i get home
Btw, managed to score genuine Impul sides and rear bar. One's in yellow (sides) and one's in white (white) so you can imagine the length i went thru just to source em lol. Trying to look for a place for spray painting and fitting now. I'll post the pics once they r done
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4652771
Thats tops my whole impul kit was $1100 if its not perfect im going to flip! How much was fitment mate? BTW i vote lose the eye brows and use NISMO eyelids - hard to get but take a look at the SIGNAL AUTO R34 GTR and you will understand why (needs a front shot)
https://www.sau.com.au/forums/topic/273883-r34-grill/#findComment-4655601
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
