www.racinglab.com/rotawheelsd2.html
Ok I'm about to order a set of these in 18x8 +25 fronts and 18x9 +30 rears according to the offset calc it will sit nicely (unless someone can advise me better) on my r33 gtst
My only problem is I'm not sure why it means when it says 5x114.3 +35mm 73 hub (what is 73 hub?)
Other than that these look damn sexy and will set me back only $1260 delivered and weigh only 10kg each which is decent
https://www.sau.com.au/forums/topic/273884-buying-wheels-from-america/
  • Replies 53
Yup just checked the details of my set it's 18x8 +25mm 73 hub and 18x9 +30 73hub all in 5x114.3 , if someone can tell me what that 73 means it will be awesome! Btw not buying from that site which is more expensive.
Are these available in aus?
you should still request if they can provide hub rings just in case.
bit off topic, have you already got a quote to bring in to aus? I;m in the process of buying a set of swaybars for my car and delivery is going to cost almost as much as the swaybars themselves lol
$400AUD bloody expensive but these look nice and still cheaper than buying decent rims here, unless I bought drifteks which are a decent price, so I'm tossing up between those 2, still waiting on a reply from wheelworx!!
If you are planning on lowering your car to the hieght where the tyres sits under the guard, you will have to throw in a bit of negative cambre to make them fit.
I got 18 x 9 +32 on mine, and I have to have around -1.2 negative camber to ensure the wheels dont rub on the rear guards.
Cheers.
Cheers.
wrong... you do not HAVE to run negative camber at all, just roll your guards a lil.
adding negative camber to make rear wheels fit is just stupid from a performance perspective.... especially when you are looking at 375rwkw. skylines give themselves enough neg camber when you slam them as it is!
i run 18 x 9.5 +30 on the rears with positive camber, and they sit almost flat.
18 x 9 +30 will fit easy... although i'd go a bit wider imho... yours will sit 6mm in from mine.
for reference i run:
235/40/18's and
5/7kg coilovers
positive camber a few deg, but cant remmeber exactly
car is 10mm lower than in that pic now (320mm centre to guard)
i can just 1 finger up to the second knuckle between the guard and tyre
car also has swaybars and strutbraces front and rear
guards are rolled but not flared - paint did not crack
i do not get any scrubbing to worry about, a tiny bit of black on my finger if i run it around the guards, and only if its been driven hard
the 73 hub should be aight.... from memory mine are 76mm and i had custom hub locators made up, but most people that run professors dont bother...
235/40/18's and
5/7kg coilovers
Why would you run 245s on a 9.5 wheel?
Yes, with 245 tyres, it will fit under the guard. Why you would put 245 tyres on a 9.5 inch wheel puzzles me, but ey, whatever tickles your fancy.
I have 265/35/18 tyres on my wheels, hence, the reason why I had to place a bit of neg camber to make them fit under the guard.
i run 235's cause i'm one of those fitment types that you hate >_<
car makes 300rwkw, so with decent 235's and flat camber i get pretty good traction and tyres are cheap as 235 is a very common size and they dont last me long
i run 235's cause i'm one of those fitment types that you hate :P
I had Toyo R1s 235 with -0.5 camber on the rear with my R34 GTT rims, running 256 rwkw. My car was all over the place in 1st and second gear.
I now have 312 rwkw with Khumo 265s KU31s and still decent camber, and it spins even when I engage in 3rd gear.
This may be due to the Jim Berry full monty (carbonic) clutch I have. Nonetheless, even when building boost in second gear, the car spins all over the place.
probably your camber dude... as i said we are running the same power at the moment and i'm not doing tooooo badly...
what diff you running? its a locker yeah? i'm on a 1.5 way nismo (i think left that out of that pm)
on 250rwkw with the same setup i had full traction in everywhere...
shouldn't you be running positive camber in the rear to aid traction as I said before when the car squats you get 0 camber therefore more contact between tyre and road, but I guess it also depends how much positive camber you can run
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
