  • Replies 53
Didn't read the whole thing but to the guy who started the thread, pretty sure 18" Drift-teks do not come in black, Koya only supply the black wheels up to 17" size, so if you want black 18's budget a bit more money for aftermarket painting.
Oh and I believe the Skyline gods would say that 235's on a 9.5" wide rim is perfectly acceptable, looks good and is not overly stretched (in fact tyre manufacturers say it will fit comfortably).
Look what you wrote above i.e. You run positive camber. I interpreted this exactly the way it's written.
You didn't say you dialed in more positive camber to offset the excessive negative camber, however, overall, you still retain a little bit of negative camber.
That's a bit unfair, you left out of the quote the part of his post where he said it sits almost flat...this indicated to me that he was using the positive camber to offset negative. Also, he did state in a post not long after, that he runs positive to compensate for the negative camber caused by lowering the car.
Then, maybe I was just on the same wavelength as Hamish :)
I have 18x9 + 30 on the front. I had 20mm spacer added to that so that made it +10, I had the front banged up abit and it was still scrapping so its now back to +30. If you want your car to be nice and high you could get away with the +10 offsent but mine is slammed on the front.
Edited by blags
black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black black
+1
Nice one, did you need any rolling/lipping? I can't tell it looks stock to me!
it's actually a mates car..
the guards are definately rolled though, the rear guard lips were rolled pretty flat as that was the main rubbing area.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
