Hey guys,
I've had my car running a gt3040 + gizzmo ebc (non MS) for about a year now.
Holds boost well, given the turbo is known for surging...
While reading the forums i read up a bit on setting the gain closer to the boost level, bringing boost on faster etc.
Seems simple enough, so i gave it a test - however find that it spikes really really bad!
E.g if i set my boost to be 14psi its fine with gain at 0, but if i have gain at 13psi it spikes bad then jumps back and forward between about 12 and 16 psi :(
What im looking to know is what gain people use on their gizzmo's - is it -1psi from the max boost as the manual states? - if so do you have this similar problem?
Which gizmo uni u got? the MSIBC or the IBC?
I have the msibc and the rule of thumb was NOT to have the gain the same or higher then the duty cycle..
eg with the stock turbo/actuator i ran 25 gain and 30 d/c and it gave me around 8psi (i think).
If you set the gain the same as the d/c or higher, you WILL get creep/surge issues - Why, i dont know. I think its just how fast the actuator opens/closes the gate.
What is the setting on ur controller when u get surging? ie d/c, gain..
Also, youre running closed loop i presume?
Running the IBC, not MSIBC as stated
Gain is set in PSI amounts, D/C is set in values between 1-100 or whatnot to open and close the solinoid at the set intervals.
So in this case the D/C is a value of 62 giving 14psi, and gain is a value of '13' - 1psi away from the max boost under the given D/C (14psi) - so -
DC = 62
Gain = 13
The IBC doesnt allow you to set the gain higher than the set boost limit and as a result you cant set the gain untill the D/C is done and set with a boost level.
It only allows to be as close as 1psi to it, never past it and never the same - only ever below it.
So any other ideas?
How do i know if its closed loop?
Edited by Flux_nz
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
