Ok, i have a 32 4 door and the speedo is not working.
What do i need to look at to see what the problem is.
I have heard something like cable is snapped or gearbox thing is broken. What goes on these
it an 89
Speed sensor cable is snapped. Can get one for $110 new from Main North Nissan or $80 from nisswreck second hand.
-D
My rev tacho doesnt work.
It stopped after I had a complete power and electrical loss... everything went back to normal besides my dash rev tacho...
CBF fixing it because I have been told the whole dash would need to come out.
It happened ages ago, I cant remember what I did but I know I checked it out at the time and took it to an auto electrician who said they didnt know so they would need to pull the dash out. Mind you they dont know skylines well.
Feel free to take a look if I come to vilis :P
its the little speed sensor/needle.
its hard to explain, but theres this little plastic thing at the end of ur cable which cracks, common problem, if u buy a replacement one it will probably just happen again, especially with drift etc.
people usually say just put a cable tie around the tube to hold it in place, we got some very thin wire, wrapped it around, then put some araldite on it to bond it. hasnt broken yet.
everyone is correct,
takes about 30 minutes to install, and with 2 people its easy as.
Pull out your cluster
Undo speedo drive out of gearbox
Look under your brake master on the firewall in the engine bay, there is a triangle looking black rubber/plastic about the size of your palm. Held in with 3 bolt, undo them.
Get back in the car and look at whats left behind your cluster there is your speed drive, push it too the left and it unclips. You should then be able to pull it out through your firewall into the engine bay.
Repeat in reverse.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
