rb25 turbo engine & gearbox combo
engine has 140 000 kms
all standard inc turbo and cooler
still in car so can hear it running
full engine with manifold and turbo loom and conputer gear box will come with all cylinders and pedal box
can include tailshaft if necesary
comes with everything you need
$3200
or will seperate if a buyer is found for both,
*will be wrecking a full 33 if these sell so if you chasin anything in particular let me no
https://www.sau.com.au/forums/topic/273936-fs-rb25det-engine-and-gearbox-3200/
What year is the 33? S1 or S2
Where is the car damaged?
the car isnt damaged anymore it just needs touch ups and prep work and a spray job i just cant be bothered with it anymore, you may remember a little while ago i advertised the full car with the damaged back gaurd.... well a new back gaurd was fitted and the car is now straight but i have really lost intrest now and want to part it out so the engine and gearbox will be sold first then the rest,
or if someone wanted to buy the lot i would sell it cheap!
  • 1 month later...
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
