Hello,
While playing around on the weekend i found the self diagnositc mode for the Navigation system.
In this mode you can test all components connected to the DVD rom navigation unit, eg tv tuner, gps antenna, etc.
I also found these extra screens.
By pressing the MAP and DISPLAY buttons together for 5 secs you get into the diagnostic mode.
The first screen has 2 options, the top option is self test, the second one has this screen
If you hold the MAP and DISPLAY buttons down for another 5 seconds on this screen you get this one
You notice you get the additional function of SRAM (i think this resets the whole system)
If you take the 3rd option down it has 3 functions -
1st option is gyro angle adjustment
2nd option is speed calibration
3rd option is this screen showing all gps data
I have tried to work out what each set of figures mean?
Can anyone else work out what the different menu options say?
Cheers
Pete
i forgot to ask a fellow stagea owner on the weekend. if i see him thursday night ill ask to borrow it and ill attempt to copy it. ill make an image of it available assuming it works. maybe a torrent or something.......
disc is a DVD and yes it can be copied.
one item you missed there was the greyed out langauage button.
these screens were covered about a year ago and the translations of the sub menus.
Regarding the 1st option.... I wonder if that would solve the 'inaccurate' Compass direction?
Have you tried if you can make some custom adjustments in any of those options/screen?
The best way is probably install a Japanese IME on your laptop, bring it over to your car with a local WIFI to your home ADSL, and you can translate most of the screen easily using google translators...
have a chat to andy - his username I dunno but he organise the work on russian translation thing... I think it's andy56b or something like that...
have a browse on this forum you'll easily see his name come up around
I played around, didn't get anywhere... almost killed my battery since took me some time with laptop and google translator with Japanese IME character recognition pad open, lots of copy paste...
Going into navigation directional setting there is one setting where you adjust the % (accuracy?) with left and right turn, I am not sure what it is...
probably trying to compensate for delay in the GPS signal and tuning the timing between a turning timing etc? well what the heck...
it's a finicky to work with and cbf anymore...
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
