Hi,
I have my R32 GTS4 up for sale i have owned this car for 3 years and was the first owner in AUS car came into AUS with 82,000km and full nissan history till i got it and did my own servicing
I have spent many hours and $$ working on this car, but its time to let it go in way to make way for the GTR.
Most parts were new or nearly new when they were put on the car.
Engine is stock internal RB20det with 106,000km serviced every 5,000kn or sooner
Hyper gear TR43 gen2 Turbo 5,000km old
Custom dump heat wraped
Gktech front pipe with o2 sensor bung welded in.
xforce high flow cat.
Hks super drager cat back.
silicon intake pipe
Apexi pod
Tomei metal head gasket.
Tomei inlet cam gear
OS giken exhaust cam gear.
GTR injectors
GTR resistor
GTR fuel pump
GTR Power FC modified by creatd for RB20det
Power fc Hand controller
Z32 AFM
Apexi pen turbo timer
Power fc boost kit
Hybrid front mount intercooler kit.
Nismo low temp thermostat
Gates timing belt
new water pump
new idler bearings
Remote 13 row oil cooler kit with brand new speed flow fittings.
Front and rear strut braces
just jap b pillar brace.
Hicas lock bar with hicas pump removed and re-routed power steering fluid through the oil cooler. Not the block off method.
Rear subframe pineapples.
Exedy 5 puk ceramic button 10,000km old
DBA 4000 front rotors
Hawk semi comp front pads near new nissan rear pads.
Cusco brake master cylinder stoper.
Cusco oil catch can.
HKS lowered springs
Good condition front shocks.
KYB super special 4 way dampener rear shocks
Just jap castor rods.
New nissan tie rod ends
Super pro front upper camber bushes.
Stewart Warner 3 din gauges oil temp oil pressure and boost.
Drift steering wheel.
Panasonic mp3/wma head unit.
Sub wire run but not used.
JVC 6x9 rears mounted so the parcel shelf is not cut.
Window tint JDM style
6000k HID kit
Full Type M body kit. Spoiler removed but included.
N16 pulsar hatch side blinkers.
Custom colour R33 GTR rims.
Clean and good condition interior.
Clean and good paintwork apart from the holes for the spoiler which have rubber grommet's in them.
Car made 215rwkw @18psi on creatd dyno
Also made 230rwkw @19psi on my own dyno
PH 0438 804 282
Price:
13,000 with rego till march 2010
13,500 with rego till march 2010 and vic RWC
9,500 with rego till march 2010 but with out power fc, boost kit, GTR injectors, HID's, Z32 AFM, turbo timer front + rear strut braces, b pillar brace, cusco brake stopper, cusco catch can, cam gears, nismo thermo, oil cooler kit, GTR will have stock 32 rims and gauges. Without the power fc injectors afm will be replaced stock ecu with cef11 remap stock injectors stock afm.
https://www.sau.com.au/forums/topic/273969-1990-r32-gts4-black-type-m/
  • 2 months later...
The car will now have an Adaptronic ecu with 3 bar map sensor and boost controlled by the adaptronic.
Also happy to sell it for less just throw me an offer
  • 5 months later...
CAR WILL NOW HAVE THE FOLLOWING:
NOTE THE CAR WILL BE SOLD WITH STANDARD R32 GTS-t RIMS WITH RWC RUBBER
silicon intake pipe
Apexi pod
GTR injectors
GTR resistor
GTR fuel pump (Hard wired to the Battery)
Standard ECU with DMD Tuning custom re map
Gates timing belt
new water pump
new idler bearings
HKS lowered springs
Car will be sold with a RWC for an extra $500
Car will also have 12 months rego when it runs out at the end of March
11k
It's sitting in the shed under in cover time to go
I will swap you a 1977 Mazda 121 (basically a RX5 without the rotary) and a queen size gel bed (worth $4,000 plus brand new)? Removed anything of value in the car that won't in anyway hinder the function of the car and we will work out the cash difference?
PM me this is serious strangely...
Thanks mate for the offer but I need the cash to spend elsewhere.
I'm returning to melb at start of april and if it's still for sale i'll be around to have a look
cheers mate I'm hoping it will be gone by then
  • 2 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
