Big Scam Or Great Deal?
Its called the "sail panel". 'Coz it looks like a sail.
Yeah, but what boost. That sounds like 10 psi. There's a bit more available at 12, and the extra is worth the risk.
Believe it or not, it's about right, remember it's also the 4AT which is worth a good bit too. This sounds along just right with everything else ever posted here on a stock turbo at reasonable boost.
Ok, thanks, legends. I'm hoping I don't need to pull out the window regulator. I was thinking when the window is out, the regulator mechanism shouldn't interfere with the corner piece and then be able to be removed through the speaker hole. Fit the new corner piece and then refit the window, and Bob will still be our uncle.
Sounds spot on. My R33 gtst with a bit of boost made 162
