1989 R32 GTR including new paint engine build and gearbox build up 80,XXX k's since full rebuilt
The list:
Forged Engine
CP Pistons
JUN Oil Pump
SARD 700cc Injectors
N1 Water Pump
Oil Drain Added To The Rear Off The Head Back To The Sump
TOMIE Oil Feed Restrictors
TOMIE Sump Baffles
HKS Adjustable Cam Gears
Apexi Cams
ACL Race bearing Throughout
ARP Mains + Head Studs
TOMIE Head Gasket
HKS Timing Belt
All New Hoses And Gaskets
Also In The Bay
Oil Relocation Kit + Cooler
After Market Radiator,
After Market Cooler Piping And Radiator Hoses,
Nismo Airflow Meters,
K&N Panel Filter In Standard Airbox
New O2 Sensors
Huge 600x300x120mm Intercooler,
Garret -5s Capable Of 430+ rwkw
Gearbox Was Completely Reconditioned
Including Syncros 2/3/4/5
3/4
Every Seal And Bearing Has Been Replaced
RECENT RETUNE USING NISSTUNE 03/06/09
341rwkw on 18 psi now, on a safe tune
DYNO PAPERS PROVIDED
Other Parts Changed Out:
New Coil Packs
The Altessa Pump Changed
Hicas Lock Bar Added (Rear Powersteering Pump Impeller Taken Out To Completely Disable It But Still Keeping The Cooler)
Bilsteine Coilovers All Round.,
Very Good Condition R32 GTR Wheels
D-speed Clear Indicators,
Front + Rear Sway Bars Also One In The Middle Of The Car.
Torque Split Controller Added With a 2wd/4wd Switch (In The Console)
Boost Controller Hidden In Fuse Box.
I Am Selling My R32 GTR Because Im Going Oversees At The End Of This Month...
PRICE 24k
There Is 11 Months Rego On This Car And Will Come With RWC...
Cheers, Taner 0403172796
https://www.sau.com.au/forums/topic/274000-r32-gtr-heavily-modified/
Who built the motor? Do you have reciepts. Were you the owner who built the car or was it the previous owner?
Genuine buyer, its just that the colour looks familiar.
Cheers
You can pm me if you prefer
This was for sale by a different member (Peter is his real name) in a previous ad a few months ago (maybe more??). The lack of info and responses to genuine inquiries from this seller amazes me. Ive given up after sending 2 emails.
I have the contact info for the previous owner as I was emailing him when this car was on carsales (and here simultaneously). The distance and over the pits rego hassles, kinda killed it for me, but it's a great car.
Cheers
hey man, the previous owner was peter...
the engine was built by him and john at ices performance in rowville.
the only reason why im trying to sell the car is because i need the money as im going oversees and to buy 2 cars for myself and my brother.
im barely on SAU so just call me if you have inquiries dont email me...
my number is 0403172796 or my brother 0423350450
i havnt recieved any emails from you...
Click on your name and view your profile.
At the bottom of the LHS is the contact information and at the bottom of that it shows your email address that you must have registered with??
It shows this:-
[email protected]
If your info is wrong, well that's your fault.
Now you spend $X (half with your brother) on buying a car and then 5 seconds later youre selling it as you realise you need a car each? Well der! WTF? I thought you were selling as youre going OS?
Ice Performance where in Cheltanham, not Rowville, there was no John there, just a Greald and Nigel, I know because they built 2 engines for me and are friends.
Cheers for the help anyway, I guess you dont know much about the engine.
Good luck with the sale buddy.
To help out the poor fella trying to sell this, it appears that the previous owner Pete, worked at ICE a while back. He now work at Rowville (I guess a mechanical workshop??). Engine definitely done at ICE though.
Im also guessing that if Nigel and Gerald are mates, ask them about Pete and this car?? I assume they must know of it?
Edited by xthommox
It shows this:-
[email protected]
yes i wanted to sell it to go oversees so i have money to spend from my half of the money that i recieve...
and then the left over i can buy another cheap car!
i think youve got the wrong one.
ice performance and ices performance are different...
ahh thanks for the info =)
i dont know much about peteshistory but its good to know now he use to work at ice.
Edited by gtrkid123
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
