i used the same system for a cefiro with a 25 box worked perfectly, i used the navara speedo drive (32702-02G17) nissan part no. burnt the cog off, used the red gear on the speedo drive out of the r33 box. rounded out the middle of the cog, heated up the navara drive and tapped it on, super glued both ends. cut the slot for the locator and all good.
cheers heaps
ive got a gtr one in mine atm but it reads like 10-20-30kph off (increases with speed)
is the navara/vl one accurate?
(it doesnt bother me too much having wrong speed as i can gauge off the revs-except in school zones.. dam 40kph have no idea what speed im doing)
Edited by Char
I'll have a search for my post with the cog tooth count vs final drive ratios.. the 17T standard Navara cog is a pretty close match for my 3.9:1 diff gears (reads 7km/h high), you need the correct toothed cog to suit your diff gears.
7km/hr at what speed?!? The amount that the speedo would be out would vary with speed...
Mine has a 4.3 ratio diff and is out by about 7km/h at 60km/h but 10km/h at 100km/h etc etc
@ 100km/h I'm actually doing 93km/h
i was actually wrong, at 72 speedo im doing 60 gps and 127 speedo 100 gps
in other words its miles out :thumbsup:
  • 2 years later...
  • 4 months later...
  • 3 months later...
  • 9 months later...
just had a sensor shaft snap after this mod. the pics arent working can someone explain the 180degrees out for the locator pin for me? i didnt do any of that and maybe thats why it snaped. i just pressed the cog on and installed.
  • 1 month later...
  • 3 years later...
  • 1 year later...
Did the conversion today and I took some pics as the original images are down.
KpiwlM6.jpg?1
Required parts.
What the drive looks like - note this one *came out* of the gearbox (didn't know what was in there). I didn't get any pics but I used a combo of a (n eventually plastic coated) cutting wheel, carbide cutter and a carbide burr on the dremel. You can see remnants of the removed black gear in the bottom right of the image. Recommend you melt it off instead, it'll be a lot quicker and less worried about damaging the spline on the shaft but messier.
What I didn't get was a picture of the flat I cut into the splined shaft. Cut 12mm down from the edge to match the new gear, or cut the flat from the gear. Either way works.
Note the gear shaft offset from the body. Also note the notch in the centre bottom, above thumb nail.
Note the difference in gear size. The shaft housing needs to be rotated 180 degrees to make room for the bigger gear. The body will spin in the gearbox but you'll need to cut a new slot for the retainer.
Original retainer location in relation to notch.
*NEW* retainer location in relation to notch which needs to be made. It's mirrored around the notch. Approx 3.5mm deep x 20mm tall and 4mm away from the edge (from memory).
Cut it with three hacksaw cuts. Could use a dremel or a square file instead.
I didn't neaten it up at all as I had already cut a tiny bit too far.
New gear on. I applied a bit of araldite to the flat area just to be safe. Don't use superglue as I think it may melt the gear. Notice I started cutting the flat out of the gear, before realising I could cut the shaft instead (and would provide better location on the shaft, not that I imagine there's much force on it anyway).
Note, the gear doesn't bottom out on the housing like the black gear. Top of gear is flush with the shaft (as shown in an earlier photo).
Going into the gearbox - if the gears are meshed, it should slide up to here with minimal effort. Note the location of the notch in the speedo drive body (should be pointing down).
All done!
  • Like 2
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 馃槢 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
