xanavinismo Posted June 9, 2009 Share Posted June 9, 2009 Hi all, How much power can the stock R34 GT-R air flow meters handle before it needs to be upgraded to bigger afms (Z32's) for more power? To my understanding, isnt it around 300rwk's and not much more? Cheers, Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/ Share on other sites More sharing options...
kefe69 Posted June 9, 2009 Share Posted June 9, 2009 Don't now about max but i'm still using stock and i have 310awkw. As soon as i can i will be upgrading them though.. Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4646458 Share on other sites More sharing options...
Duncan Posted June 9, 2009 Share Posted June 9, 2009 they will run to maximum voltage somewhere between 280 and 300kw. From there the tune is "blind", there is only a single point in the ECU for all airflow above 5v which means it is compromised in both fuel and timing to make sure it stays safe. Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4646547 Share on other sites More sharing options...
Swiper the Fox Posted June 9, 2009 Share Posted June 9, 2009 they will run to maximum voltage somewhere between 280 and 300kw. From there the tune is "blind", there is only a single point in the ECU for all airflow above 5v which means it is compromised in both fuel and timing to make sure it stays safe. yep Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4646575 Share on other sites More sharing options...
Guilt-Toy Posted June 9, 2009 Share Posted June 9, 2009 yep what he means is if its tuned and maxed out at 20psi, if the car overboosts or you turn the boost up the state of tune will not change as the ecu does not know the boost level has changed so it could cause detonation or a too lean of a mixture for the extra boost. it works the other way as well, if the afm max's out at 17 psi and you tuned the car to 23psi, then you decide to turn the boost down to 17psi, then it will run too rich and you won't be getting the right power / mixtures for that boost level So its kinda ok but not recomended to tune the car with a maxxed out AFM, if you dont intend on changing the boost at all then you can possibly get away with it if you have a decent boost control that will never fail and overboost Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4646591 Share on other sites More sharing options...
xanavinismo Posted June 10, 2009 Author Share Posted June 10, 2009 Thanks everyone for all of your replies. I will be having the following mods: Garrett GT2860-7 turbos Apexi Power FC Apexi Power FC Boost Control Kit (running 1.2, or even 1.3 bar) Nismo 600cc injectors Nismo fuel pump Apexi Power intake kit HKS cam pulleys Tomei Poncams 260's type B HKS Front pipe HKS Cat Blitz NuR cat back So im guessing that with all of the above mods and the boost that I hope to be running (1.2 or even 1.3 bar) I should upgrade afms? I was thinking of the Nismo afms... Cheers, Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4646908 Share on other sites More sharing options...
Beer Baron Posted June 10, 2009 Share Posted June 10, 2009 yeah I would. and I would get the nismo afms too. I went new gen nissan Z32s on the last GTR, and nismos on this one. performance wise they are very, very close. and the nismos have the advantage of being standard size. Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4647037 Share on other sites More sharing options...
xanavinismo Posted June 10, 2009 Author Share Posted June 10, 2009 (edited) yeah I would. and I would get the nismo afms too. I went new gen nissan Z32s on the last GTR, and nismos on this one. performance wise they are very, very close. and the nismos have the advantage of being standard size. Oh ok so the Z32's are actually bigger than my stock ones? Which means they wouldnt bolt straight up? And the Nismo ones would use the same ECU plugins? Also, you dont think its over kill to get the Nismo ones for my application with the mods I have listed above? Cheers, Edited June 10, 2009 by xanavinismo Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4647047 Share on other sites More sharing options...
Bakes Posted June 10, 2009 Share Posted June 10, 2009 What about Power FC D Jetro Glen? Then you wont have to run air flow metres at all. Just unplug them. Thats how mine is with my Vipec ECU Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4648161 Share on other sites More sharing options...
R31Nismoid Posted June 10, 2009 Share Posted June 10, 2009 For 1.2-1.3 bar, i wouldnt bother upgrading until you actually know you've maxed them. I think its undue spending at this point. You might well find you might come close, but they wont actually max @ that boost level. Every setup is different of course And ye, if you do max them - Nismo all the way. Z32's are too much of a stuff around. www.perfectrun.com.au are the cheapest for Nismo's that i've found recently... they can get em cheaper than an importer i know Perfect run (providing stock) should have em here in 2-3 weeks so its not as if you have to wait forever anyhow. Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4648193 Share on other sites More sharing options...
xanavinismo Posted June 10, 2009 Author Share Posted June 10, 2009 (edited) What about Power FC D Jetro Glen? Then you wont have to run air flow metres at all. Just unplug them.Thats how mine is with my Vipec ECU Hi Bakes, unfortunately I already have my normal Power FC installed so its too late for D Jetro? Oh and R31Nismoid, thanks for your input. I am most likely heading towards that direction where I get the car tuned and see if they do actually max out cos then I can always replace them with the Nismo ones if necessary. On a bit of a side note, should I also upgrade the fuel pressure regulator to handle the Nismo 600cc injectors & Nismo fuel pump along with the other mods I have? I am thinking of the Nismo adjustable fuel pressure regulator... Cheers, Cheers, Edited June 10, 2009 by xanavinismo Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4648826 Share on other sites More sharing options...
R31Nismoid Posted June 10, 2009 Share Posted June 10, 2009 No, you do not need a regulator. Factory Nissan all the way. If your injectors suit the power (which they do), the factory FPR always wins out as its free Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4648853 Share on other sites More sharing options...
Bakes Posted June 10, 2009 Share Posted June 10, 2009 Glen, if you want a Nismo fuel pressure regulator I have one I am going to sell. Its only done ~3000Klms. PM me if your interested. Link to comment https://www.sau.com.au/forums/topic/274004-flow-potential-of-r34-gt-r-air-flow-meters/#findComment-4649042 Share on other sites More sharing options...
