Its about to use a Haltech Platinum pro, Same as Haltech use in the R35 GTR Plugins.
This system is CVVT and has a its own Cam angle sensor so the ECU can Map Cam position, Haltech Pro ECU support this, Many aftermarket ECUs only chase a PWM that you set and this changes with oil temp etc so using the Cam angle sensor is a must to do a good job.
