Hi fellas,
I am planning on purchasing my 740cc injectors from the US, they seem to be about $300 cheaper than anywhere else.
My question was, there is a person on eBay selling HKS injectors 740cc, but he also has in the title Nismo.
Are these injectors made by the same manufacturers?
Many thanks.
Hi fellas,
Many thanks.
Denso make nismo/sard/hks/power enterprise/tomei etc etc
They make most of the injectors in japan. (correct me anyone if i am wrong please)
got any pics? are they red in colour ? can you see Denso written on it ?
The picture is way too small to see.
You reckon you could please have a look and tell me what they are:
http://cgi.ebay.com/ebaymotors/HKS-Nismo-7...sQ5fAccessories
Also, do the HKS have the same 4 hole spray pattern as the Nismo injetors?
Cheers
Dude i've said before - go easy on the bumping. You dont need to bump a thread after 4hrs because you dont have an answer.
Be patient!
In other news, just because they are made @ the same place does not mean they are made to the same specs.
I would imagine various brands to have varying setups/configurations.
As for the US being cheaper, you do realise that its in USD dont you? So $900 USD is actually at least $1100. Which is no cheaper than the other prices/places ive told you too look on previous occasions.
as Gt said, they would be generic injectors from jecs or denso or some other OEM manufacturer
nismo wont make them, apexi wont make them, and so on
they just market them as their own, brand it and bump the price up
Be patient!
Sorry fella, have trouble with patience.......
Yeah I do realise that, but seller said he could do it for $790 USD + $50 postage, which comes to about $1,050 AUD, which is more than $300 cheaper than Sliding Performance, and about $120 cheaper than nengun.
ANyone got 740cc HKS injectors?
Maybe I should just stick with the nismo... so annoying.....
Stand back a sec...
How much have you spend on your entire build?
Does the $100 really matter now? :)
Yes, it means I won't be able to eat for 3 days....
But yeah, you're right.... They are just so much!! Slide used to sell them for $879, not $1,379!!! Far out, the economy didn't turn around that much...
they are just injectors? what are you so worried about ?
I am worried about:
1) Spray pattern,
2) Latency
3) Ohms
4) Whether they will be able to run on a VIPEC V44.
I know the nismo ones work fine, as GT is running them, but I am not sure about the others.... i.e. HKS, SARD etc..
buy them. they will be fine. they are the same injector as the Nismo's !!!
with the V44 you have to run high imp injectors. if you want to run low you can but you need to convert the system over which is not needed for these injectors because they are high imp injectors for RB25DET.
just ask the guy who is selling them if they are a 4 hole injector, if they are then the spray pattern will be good. also double check that they are high imp.
also double check with him that they are not high flowed standard injectors and they are the HKS branded ones.
if all this checks out okay then just buy them and stop wasting time
um actually it did.... do your math yen was 97-101 then dropped to 55..... nearly half..... and guessing he is sitting on stock he bought around that price a month or two ago he would be fair to ask for nearly double..... simple maths.
nismo or hks same thing from the denso factory, the sard, powerenterprise and blitz etc are a little diff but still from denso. In your setup VIPEC/ LINK you would not tell between any of them as they are all high impedance.
Quick tip: JZA80 injectors fit fine and there are a million places selling them cheap in the usa if you really want to save a few $$$$ (i cbf'd with time factor though)
Edited by URAS
what size are the JZA80 injectors?
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
