My excedy 9 puck cushioned clutch is dead. It lasted about 12 months. 8 of those months was with a mild 260rwhp the rest was 390rwhp. My car is a daily driver and i travel in a fair bit of peak hour traffic on the weekdays which is not what hd clutch's are designed for. I made it clear what the car would go through and the power i would like it to handle 300rwkw.
I dont want to spend over a grand for a clutch but i want it to last more then a shitty 12 months. Is anyone on similar power that has had there clutch last similar conditions. I wouldnt say i am hard on the clutch either it has been treated fairly well.
https://www.sau.com.au/forums/topic/274063-hd-clutch-for-300rwkw/
Excedy hyper single. Pricey but wicked. Have had mine for 4 years and has copped all types of abuse and tons of city driving.
Also every man and his dog on this forum swear by Jim Berry (i've never used him but have his number on standby in case i ever need to).
07 3847 9999.
07 3847 9999.
according to nengun that excedy hyper single is rated to 400hp, i assume that is at engine too so that wouldnt last. What power you running?
Shit never knew they were only rated at that i'll have to have a look for myself.
I had it installed prior to me decieding to power up and also due to failure of the stock clutch after i first upped my boost. Whoops.
Dont be too fooled by the power rating on a clutch as they are testing it at extremes and rating it to a safe limit for hard use... warrenty crap!
If your not doing high RPM launches or dropping the clutch on gear changes then i dont think you will need to over power the clutch... i am running over the reccomended limit on the stock clutch 300rwhp and never once had it slip and i have had that power for over 2 years now... and i am pretty hard on my car and launches... but if i took it on a track i bet it would heat up and be destroyed in one day.
Decide how your going to drive and then decide on clutch dont just look at power as most will hold the power once engaged..
I was in the same boat, thinking I had stock clutch and "wow omg it's lasting strangely long"... turns out there was a Nismo organic clutch and a Nismo chromolly flywheel in there.
Well i just had a 40 minute conversation with Jim Berry. I remember speaking to him a year ago about the same thing. It was even more torturous the second time. A man full of knowledge and useful answers to my questions but fark i basically had to beg him to get off the phone.
I am sold though
either full monty organic or carbotic. $1050
And yes to Nismogtt you are right on the money
I am sold though
ahahaahaha brings back memories.
well ive got the carbotic 4200lbs gtr pressure plate 6 puck clutch from jim and im about to tune it up wiht my 2835 pro s kit on my r34gtt.
ill let you know how it holds up.
but ill tell you now it feels pretty close to stock but bites like a pitbull.
Would be nice if your right and i do have a NISMO or something... means i wont have to replace it for a while still :P
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
