Post up a list of the parts used in those quotes
There's so much GTR experience on here, you'll get unbiased advice on whats needed and whats not for your intended use of the car
LOL at BB
I kinda agree with Femno its not a bad decision buying a car in need of a rebuild but I would never buy a car sight unseen
Only real downside is not being able to drive the the car... driving it is where you ascertain the condition of the driveline (gearbox, clutch, diffs, transfer case etc)
Its a gamble but buying cars is always a gamble... x 10 if its a turbo import
Those quotes are pretty damn cheap, budget for twice that and you will be safe... also offer the guy 10K and see if he's interested... can't hurt;)
why ask for advice then if you only want to listen to people who tell you it's a great idea? as someone with experience with lots of engine builds I can tell you $4.5K will get you bugger all when it comes to an engine that is stuffed and full of ceramic. especially since this engine has had turbine wheel through it most likely head is throw away, block too, new head and new block, new pistons and if you're smart new oil heat exchange and new intercooler, and then start on the rebuild, plus labour to remove and re-fit and the bill starts mounting up. but hey, if a workshop that is looking for business told you it's true then it must be. I can think of plenty of people who get 'quotes' from a workshop only to end up with a bill at double the original price. did either of those quotes include 2 new turbos? because you would have to be retarded to put some ceramic time bombs back on your brand new engine. so figure at least $2500 for some steel wheel garrets. that's half your rebuild budget gone just on the turbos. but what would I know.....
this is the advice i was looking for at the start of possible issues i could come across i just didnt need the sarcasm
look, if you had owned 5 GTRs and been through 3 different RB26 rebuilds and had built up relationships with various tuners and workshops and suppliers then it's probably a reasonable idea. but since you don't know a lot about GTRs, or engine builds or any of the specific problems they both have I would say you are leaving yourself open to a world of hurt. given how stupid cheap all model GTRs are right now there is just not a good reason to make your first GTR one that isn't working. enough of them go from great to broken as it is! at least start with one that works. if down the track you decide you want a project then by all means go for it. but I just think it's a bad place to be with your first GTR. there are so many nice, neat, running, cheap GTRs out there.
I agree with Beer Baron. Why go through all the headaches?
Unless you could build half the engine yourself and get parts cheap than go for it. If not, i wouldn't bother.
Edited by PM-R33
im looking at a rebuild shortly, been quoted around 8k from well known melb shop (cracked ringlands)
- forged pistons
- forged rods
- full bearing set
- crank collar
- crank oil gallery tapped and scew
- oil restrictor
- redesigned sump baffle
- metal head gasket
- N1 oil pump
- genuine water pump
- timing belt
- new gaskets and seals
- all machined and balanced
- head check - crack, pressure test and decked. (if valve guides or seals need replacing additional cost will be added)
- external oil return from head to sump
- run in and tuned
back on OT, if you can afford 10k for rebuild, buy the car and rebuild via good workshop, after that you will have peace of mind.. even with most gtr's floating around, buying one in good nick doesnt mean it wont fail down the line, unless u find an example with recent rebuild..
Just wondering, with all these 6-8K rebuilds, is that engine removed + rebuild + engine back in?
Or is it 6K for the engine rebuilt + labor for installation / removal...
how much power do you wanna make? maybe even a basic rebuild will suit ur needs.
ive seen an engine on here for sale, cant remember whos selling it, had perfect compression, (i think 170psi across each cylinder), only 44000kms for pretty cheap
youve got afew options, it all comes down to how u wanna go about it
goodluck
Edited by SiR_RB
If its got other good quality bolt on bits like ecu, exhaust, afm's, suspension etc then i say go for it.
But coming into the import scene fresh and having no relationships with workshops/suppliers (like BB said), be very careful and get everything in writing, there are ALOT of shonky people around that are more than willing to rape u stupid and think nothing of it.
Thats one thing to be very careful of
hey mate,
i would say dont buy it!
i'm going through my first rebuild and all i did was spun a bearing in a R32 GTR.
the price is up to 10k, should be getting it back next week.
its taken 10 weeks for the rebuild to be done, and the car was sitting in the garage for 3 weeks before the mechanic even saw the car.
the headache of not having a car for that long is terrible.
trust me, you're getting a LEMON!
if you cant afford a good condition GTR "DONT BUY ONE"
i have spent just about 20k on my R32 over the past 2 years, and i bought it for 18,500 and it was stock.
spent $3k on turbos, $1k exhaust, $2k clutch, $2k suspension
the bill just goes on
someones gonna have to put the TLC and the $$$ into the one you're looking at, the big question is:
'do you want that to be you?'
shop around a little more
just my two cents
BREZ
Well if youre considering buying the car not-running, then im guessing the troubles of not having the car to get around in wouldnt apply to you.
This could be a good start to the world of GTR ownership...I did exactly what youre thinking of doing about 4 years ago, bought my car with engine in a million pieces, thought it would be cheap to fix it up myself and have a great car. At the end of it, 18k and a year later I had a built gtr with an immac paintjob and it drove perfectly, I was lucky though. And did all of the work myself apart from applying the paint and machining the engine, if i didnt do it myself it would have been a hell of alot more!
What everyone is trying to say is that rebuilds wont cost just 4.5-6k, theyre more along the lines of 10-15k+, and thats speaking from people who have actually done it, such as myself (second engine). Have you read the thread of the 25/30 build that went from 16k? to 22k?. lol. Same principle.
So dont get a fright when a 4.5k rebuild turns into a 10-15k rebuild like we all said.
As stated it depends what you intend to do with the car. What is your power goal??? Street?? Occasional track use?? Frequent track use??
If you want to run say 250-300kw then maybe just buy a running example...and mod that. Even if you bought this and threw a s/h motor in, its still gonna cost you a fair bit to change it over, with added headaches of possible dodgy second hand motors...it could get real ugly.
If you want say 350kw odd, a built engine is preferable, so buy this, rebuild it properly, and be done with it.
Since you know not-much about GTRs, buy the car, tow it straight to Racepace, have 10-15k ready in your pocket, talk to Ben, pick the car up in a few weeks and enjoy a non-problematic GTR (fingers crossed), with an engine you know wont break a week after you pick it up.
It all depends on how adventurous you are!!!
Just my recommendation.
Remember, without being able to test drive the car you don't know the condition of anything else - clutch, gearbox & little things like power windows, stereo. The guy selling it probably bought a "cheap" GTR and can't afford to rebuild the engine - hence the sale. It doesn't have a roadworthy, you can't drive it. What the guys are saying is it would need to be $10,000 cheaper than a similar car in decent condition to justify the risks/inconvenience involved.
i'd be looking more close to 10k for a drive in drive out engine build using decent bits..
with possible new block/used decent condition one thrown in there..
you will be supprised how quick the bits for a gtr will add up.
i'd hate to think what i have spent so far on my build and i am a tight ass bargain shopper :D
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
