Hi, I own a Nissan Stagea 1998 series 2 triptronic (formerly owned by my bf who is a forum member but doesnt have net access atm). My ECU is on serious way out and I need a new one.
I was wondering if anyone had an suggestions of what I should get? I have been told with the triptronic it makes it harder to get a suitable replacement.
https://www.sau.com.au/forums/topic/274082-ecu-options/
What problems are you actually experiencing?
I can only think of one other forum member who's had a crook ECU in an S2.
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4647463
Allstar Tuning has said it was an ECU problem. Randomly I have had problems while I am driving and I accelerate there will be no power or it will backfire. The last time it happened it was while I was driving 60kms on the intercity bypass and had the fun experience of trying to getting off the road at a slow crawl. Ive had my car towed twice to Allstar and they haven’t been able to find a problem until now.
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4648192
There are some wreckers in Qld that have S2's in stock - so if you need to try a different ECU, then it shouldn't be outrageously difficult.
BUT
I'd certainly consider a bit of a search here for further information on the problem, and see if there isn't another, cheaper answer.
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4648322
umm, sounds a bit odd.
perhaps the ECU needs to be removed and re-plugged back in assuming that a pin might be making a faulty contact.
beyond that there is another issue. for a workshop unplugging and replugging an ECU should be a 5min job. for a newbie it should be a 6min job.
what mods have been done to the car? ie boost control etc?
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4648397
Try pulling the plug out of the ecu and looking at the contacts and if they look OK put the plug back firmly and do up the bolt. While you are there write down the numbers on the ecu and post them up for us to see. Maybe a Brisbane member with an S2 will trial swap the ecu or at least point you to an RB savvy workshop.
It is unusual for the ecu to pack up but if that is the problem the only other member to need a S2 ecu couldn't find one so ended up paying $2500 for a Vipec which you probably don't want to do right now. So check out everything else but post up the part number for the ecu so that we can keep an eye out for one in the meantime.
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4648988
I am in Brisbane if you need to borrow my ecu for a day.
No need to spend $2500. There are always some for sale on Yahoo japan for approx $150-200 landed here.
If you need help buying let me know
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4649026
NissWreck (www.nisswreck.com.au) in South Australia have a yellow 1999 S2 Stagea due to arrive at the end of June, not sure if they will seperate the ECU but it could be worth a try! Give them a call.
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4649175
ECU problem is quite rare. Its easy to blame because of its complexity but quite rare to have a problem. like ZEI201 i would first swap out plugs to a copper equivalent say ngk bkr6e/bcpr6e one has longer thread than the other by 2.5mm anyway.... ignition breakdown under load/boost is common and would suggest coil problem. general bad running would suggest airflow meter problem usually plug connection. A loose intake hose or air leak after the air flow meter (AFM) would cause similiar symptoms. Does this workshop deal with these sorts of cars a bit?
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4649210
Thanks for your replies. I called my mechanic (Allstar Brendale) and they confirmed it was 100% the ECU as with the coil packs my car would have just cut out, where as my car cuts out and cuts back in. Such a shame it wasnt my sparks or coil pack. They have tried a R34 manual ECU in and it works perfectly. Currently we are waiting to hear back from their jap contact and hopefully we will be able to get answer soon and I can save money as the est is $1500 from them.
Also for the people that I have pmed me I am unable to pm back as I am a new member and havent posted more then 10 times. Thanks for your pms.
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4651526
not really, coilpacks can be affected by heat, and if the temps are changing enough, they will cut in and out. plus its a sign that they ARE beginning to fail.
if they swapped it out for a working ECU and its perfect, then yes. change it. but $1500 for a standard ECU?? youre getting ripped off unless its a power fc with installation and tuning
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4651551
hmmmmm.
for that sort of money..... seems bad.
try this:
* Splitfire coilpacks $500 new
* bcpre6 spark plugs $20 new
* 300v motul 10/40 5L oil $130 incl ryco 201 fuel filter & ryco z145a oil filter
* yahoo.co.jp search "c34 ecu" and grab one for around $200 use sau trader Import Monster
http://www.skylinesaustralia.com/forums/Sa...er-t249331.html
example list:
http://search.auctions.yahoo.co.jp/jp/sear...=0jp&acc=jp
one that will fit:
http://page5.auctions.yahoo.co.jp/jp/auction/e89091024
import monster will give you a price and win the bid for you, then deliver it.
good luck, save your cash, and try another tuner?
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4652023
straight out my list saves you $500
but gives you a fresh secondhand ecu from japan, delivered within a fortnight
also gives you brand new working coilpacks and good copper sparkplugs/oil.
fresh service, will feel good, an hour on the dyno will make her feel great.
Id even suggest using an adjustable fuel pressure regulator $180 del
a safc-II secondhand $220 del, then some dynotuning
that will spend all of the $1500 but the car will feel and perform better than ever.
now go back to the mechanic and tell him to do the following for $1500 supply & tune
* nismo adjustable fpr $180 delivered new
* safc-II $250 secondhand
* C34 ECU replacement off yahoo.co.jp $300 delivered
* service fee, labour, dynotune time $200
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4652055
most of that can be done if youre handy with a socket set and few screw drivers :D
yes even girls :)
exactly
with the labour fee saved buy a wideband air:fuel guage / monitoring system
and learn self-tuning
hai five's
http://cgi.ebay.com.au/Haltech-Haltuner-Ai...93%3A1|294%3A50
https://www.sau.com.au/forums/topic/274082-ecu-options/#findComment-4652089
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
