  • Replies 45
skids up . at least the tires wil be cheap .
Well tires will be short lived...... lol
We're also going to try and tuck a set of 19's we got with car underneith it. In keeping with the philosophy of the build the wheels we're using are a stock nissan wheel. Even so I'm going to minitub the rear and possibly tub the front. The front tubs are fairly roomy stock and given the RB+turbo will be space hungry it'll be good if the front tubs don't need altering.
What a great idea,would be a reall sleaper,keep us posted if you do it. :D
We're doing it! we've got a Cedric in the shed 1/2 disassembled and a R31 waiting to be stripped of its running gear.
Can't wait to surprise a few falcadore drivers by toasting them with grandma's stationwagon.
Loving it! Can't wait to see the end result.
Same same. Sooooooooooo much to do though its just not funny. Fortunately the B/in law is a body and paint man and as much as I'm no mechanical marvel I have tackled some tricky conversions already. (multipoint EFI in a 550hp chrysler V8, what a headache) This one is going to be the all out build though so stay tuned.
Just noticed you've got a stagea, no wonder you like this idea.... lol
Edited by Linkstar
Nice work!
I hope that you have considered the issue that the old Cedrics didn't come standard with any brakes...
:P
Tell me about it! On the day we got it first I almost sent the thing into the back of my parents navara when I was putting it on the trailer then I almost sent it backwards through our bedroom window when we got it home! The brake pedal goes straight to the floor, that must have been a factory option. :O
this is a pic of the cars owner (my better half) and the car trailer/launch ramp on the day we picked it up.
Thats where the opinions are divided here at home.
I think, given that we're going to put a rb30det in it we should go for the nostalgia look with whitewalls, 2tone paint (mint green with a white roof), painted 15/16inch steelies and a venitian in the back window.
Whereas the better half is pushing for charcole grey with blacked out 19's. I can tell you now who will win :P
use this to your advantage.... make sure you end up with this. Its full of awesomeness. charcoal grey and 19" wheels.
Just keep in mind that if you retain a pre 1970's motor you don't have to worry about emission laws and noise restrictions.
welcome to the land of no spares lol
ive got 2 cedrics bth a bit later than yours
Unfortunately I've already resigned myself to zero market support. This car makes building a chrysler seem easy.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
