Okie dokie
Now my GT-R has never felt as quick as I expected. Mods are as follows:
1990 standard GTR
Mine's ECU (rich as f**k)
3.5" catback
Standard everything else (inc airbox, dump pipes, cat etc)
107000kms
But the other day it took off like a rocket. I have since confirmed that the boost gauge tears off past 1.2kg/cm^2(!!!) and I know standard should be 0.8 bar (11.8psi)
When it isn't going berserk, it only holds about 0.5kg/cm^2... Which is well below 0.8 bar.
So this suggests to me that the boost control solenoid might be f**ked?
Any similar experiences?
Thanks,
Ryley
https://www.sau.com.au/forums/topic/274094-r32-gt-r-strange-boost-behaviour/
Mine's ECU is tuned for japanese 100ron fuel, most likely the problem is there.
1.2kg/cm^2 is 17.1psi, if that is on stock turbos you can kiss the ceramic wheels goodbye in record time, they're not meant to be boosted past 1bar (14.7psi or 1.03kg/cm^2)
thanks mate im aware that the mines ECU is for the 100ron fuel.
thankfully there has only been 3 or 4 spikes into that boost level, not keen to do it again. would like to just get the boost level set to standard.
does the ECU control boost?? i assumed that only the solenoid did??
ECU has nothing to do with boost, only the solenoid and the ball bearing restrictor (or lack of) in the hose control the boost. Should be seeing exactly 14.7psi without the restrictor (indicated by a yellowband on of of the hoses going to the solenoid), if you want to to lower the boost put the restrictor back in.
cheers mate. afer a bit of searching last night, i hve found all the hoses/schematics i need... and i reckon you're right, a boost leak.
otherwise will check ECUs. going to go for a power FC at some stage anyway. :P
thanks
ryley
Ummm...I dont understand how the problem is most likely in the Mines ECU?????
The tune on the ECU has absolutely nothing to do with the way the boost behaves in regards to max/min boost.
The excess fuel could be caused by a boost leak yes, that could also just be the tune.
What you do is:
Disconnet the line that goes to the bottom fitting of the solonoid (one that comes from the rear underneath of the collector and Ts into the actuator circuit on your schematic), and put a bolt or something in it. This will give you full actuation (lowest boost).
If you still have overboosting, its either the pressure source (split hose) or a faulty actuator or 2. You can test the actuator by blowing into the front of it, you shouldnt be able to blow air into it.
If you no longer have overboosting, the solonoid is bung, and they do pack up sometimes.
cheers mate that was pretty much my train of thought too.
the reason im leaning towards solenoid is it only does it a handful of times. normally it just sits on the meagre 0.5 kg/cm^2. but a couple of times i've given it the beans and it's rocketed off towards 1.2kg/cm^2.
but yes, i will try that procedure, thanks.
what are the standard wastegates on the turbos set at? ie what should it run with the bottom fitting disconnected and plugged??
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
