SOME PRICES
PRICES ARE PICK UP ONLY FROM MELBOURNE
MESSAGE ME FOR POSTAGE OR COURIER COST WITH YOUR POST CODE
REAR BAR & REINFORCMENT 150
STEERING COLOUM IGNITION BARREL & KEY 100
BRAKE BOOSTER ABS 180
STANDARD SHOCKS & SPRINGS 250
REAR QUARTER GLASSES 90 EACH
ROOF LINING INNER 60
FUEL TANK & PUMP 150
AIRCON CLUSTER IN DASH 60
INNER QUATER PANEL TRIMS 50 EACH
FRONT & REAR WIPER MOTOR 40 EACH
TAILIGHTS & COVERS 90 EACH
BOOT LID & SPOILER 250 CAN SEPERATE
REAR GLASS & LOWER MOULD 100
SPARE WHEEL ORIGANAL JACK & TOOLS 100
POWER STEERING RACK 180
REAR INNER SWAY BAR IN BOOT 80
EVERY THING ELSE MESSAGE ME
Edited by DIOMIO
MAKE US AN OFFER FOR THE PIECES + 10 POST TO ADELAIDE
CHEERS GIULIO
1. Drivers side under dash / under steering wheel surrounding - $20
2. Drivers side bucket handle WITH plug on bottom (in door). - $10
Plus post - $10 (Adelaide)
Total: $40
PM me your number & a time I can call.
Thanks.
Edited by TheLizard
Dude I'm after the drivers side seatbelt, must be in good condition - no wear or fraying. How much?
Can pick up from Melb and I need this asap for track day this weekend.
Call me on 0402213701 please.
Cheers J
