How much for a 92 or above r32 gts or gtst under 100 000km's in good condition??
Ive seen prices vary from 8k for a 120 000 k 92 gts in NZ classifieds, then ive seen almost identical cars selling for 20grand
After how many kms is the engine likely to screw up??? I dont know anything about engiens and i dont want to buy a skyline which needs replacing in 6 months, is there a way to check if its in good condition?? If the previous owners thrashed it i dobut hes gonna tell me
https://www.sau.com.au/forums/topic/27411-r32-costs-they-vary-alot/
As there are so many with such a diverse range of mods then its hard to give a definite answer. Myself i would be looking at a car that has already had an Australian owner, and around 15k.
They come cheaper and dearer, and only because someone is asking a certain price dosent mean its condition is reflected in the pricing.
Also i wouldnt be too worried when looking at kms, go on the condition of the car, using kms as an indicator. Noone wants my 92 R32 because it has 159,000kms, but thats fine, i know its a better car then many apparent 80,000km cars. They handle kms well, just as they handle hard driving well a long as the servicing has been looked after.
I recently bought a R32 GTSt in Melbourne and found good cars few and far between. Saw a few good ones, but many more dodgy cars.
Eg. cars with no compliance plates but somehow registered, dealers not wanting me to get the car tested then when they finally agreed found the car had been a major accident -10L dint in fuel tank, missing aircon compressor and fan, changed instrument panel.
Expect to spend at least a month looking then about $14-17k with roadworthy. Probably not worth buying a car without roadworthy if ur not really into engines, it could cost a lot more than uthink to get it on the road.
Finally, depending on ur age, make sure u have at least $2k extra for insurance.
Im only experienced with local prices. I paid 16k for my car by personally importing it myself. Back then you couldnt get a 32 under 21 thousand in Perth and they were rare as rocking horse shit.
Now you can personally import a 15 year old car for 10k-ish, but to be honest ive only seen one or two in decent nick. The rest have been really rough.
Hard to say what theyre worth, some owners might be looking at the "15 year" cars and dropping the value based on that. Others might not even know you can pick one up so cheap so they keep their price high.
Very difficult to judge.
As for insurance, not sure what its like in NZ with its copious amounts of imports, but I pay 700 bucks a year.
Red17
Always buy a car with a RWC, even if it's not roadworthy you can try screwing the mechanic that signed it buy getting them to repair it to save their testing license. I've been stung before by bargaining cars down without RWC, yet having to spend $2k getting a RWC for it myself. It's probably even better to get a RACV check, and better yet, get a mechanic to check the mechanical condition outside roadworthyness, (compression etc) to get a better idea of the engine itself.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
