Hey guys, was wondering if you could help me and a mate out. We are unsure as to whether his Silvia (Q) has a CA18 or a SR20. So I was wondering if I could borrow your knowledge and help us out :) Here are the facts:
It says 2 litre on the engine casing.
It has SR20 on the sticker on the under side of the bonnet.
It says CA18 on the metal stamp next to the import stamp.
It is a 1991 model. (I think, it may of been imported in 1991)
We are unsure which to believe, the company in which he bought it from said it was a CA18 so it doesnt matter if it is, he didnt get ripped off or anything, we are just interested.
Cheers for any help in advance :)
https://www.sau.com.au/forums/topic/27412-is-it-a-ca18-or-a-sr20/
mad max:
Is the boot badge a circle or more square?
The SR20's have a circle, the CA18's have more of a square boot badge.
Also the SR20's have round halogen lights (99% of the time) and the CA18's have the better looking square headlights.
dkonig: Be careful not to spread misinformation.. SR20's have a red rocker cover, CA18's should have a silver one.
To confuse tihngs even more, it might be a CA18 with an SR20 Engine dropped in it. :)
But yes, '91 models and above are SR20's.. And no, it would have certainly not been imported in 91.
I have not spread any mis-information, the third silver rocker covered SR20DE I have owned is parked in my driveway.
silver rocker cover with distributor rather than coil packs is from S13 Q
S13 K had the red cover and the coils
LATE S13 K had the blck rocker cover with coils but NO VVT (not sloped at the back of the cover)
S14 had the black cover but sloped at the back for vvt
S15 sort of grey colour, also sloped at back
Attached a pic of my DE (and yes I know thats a turbo on it :)
CA18DE were all Red Rocker covers except for a CA18e which was a carby smaller version of the R31 pintara motor CA20e, the ca18e which had a silver rocker cover, but this motor was only ever a Single overhead cam jusst like the CA20e.
Guest Sphyncter
ive got a ca18de red rocker silvia. dont worry about the badging and stuff cause thats no good to ya. you should be able to go from the metal stamp (next to import stamp) because these are meant to be changed whenever engine is changed (duh!) because it should have engine number on it and stuff. i know mine has had a 2L in it at some stage, but its back to the 1.8. check the metal badge, if that says 1.8 then id say its 1.8. as the guys said, without a pick we can't help ya.
as for headlights guys, mines an 88 and its got the round globes, not the square!!
-Pat
And this has been my 2 cents.....
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
