hey guys was flicking through ebay pages and came across these gt35r style turbo's from PCP from the info i have gathered it seems like they are a copy size wise and should do the same as 35r but for under 800 bucks am willing to give it a shot, anybody seen or heard of these before the more info/opinoinsthebetter for determining if i proceed with the buy or not
its 70ar and 63 ar rear internal gate
http://cgi.ebay.com.au/GT35-GT35R-SPEC-INT...%3A1%7C294%3A50
cheers guys
dan
https://www.sau.com.au/forums/topic/274123-gt35r-style-turbo-from-pcp/
Its a gamble, but not really a cheap one, they dont have any warranty, so if it dies in 2 weeks, you are $800 down. If you have that sort of money to spend, i would get a holset hx35 and get it rebuilt, should be around $800
Yeah there's a warranty, but it's crap:
*3 month warranty commences from the date the item is posted.
*Any faulty item must be returned (at customer’s expense) to PCPA. If a new item is sent, customer must pay for return postage.
*Must report any manufacture faults with-in 3 days of when the item is delivered.
*Other than the faulty part, we do not take any responsibility for damages to other parts which may have been damaged.
*Warranty is only valid by a professional mechanic which has expertise in the field in which the car part is used for. A tax invoice also must be provided to give proof of the fitting.
*Warranty is void if the item is used for any type of racing or illegal street driving.
*Warranty is void if the item is altered in anyway.
*Warranty is void if any attempt has been made to repair a faulty item.
What a load of toss.......
cheers guys
dan
Well i see some problems here, apart from the fact its a ebay turbo
1. GT35 'style' does not mean GT35 performance... if anything it wont be close in terms of outright power, response, possible surge issues
2. If its indeed a 700HP comp wheel like a true GT35... then a .63 is the WRONG choice. GT35 and .63 internal gates do not mix.
3. #2 leads me to believe you have not dont turbocharge homework with regards to the housing choices/gate setup
and ye, the fact its ebay, bush bearing
As for the others talking about warranty, its performance. There is no warranty.
Just look @ Garrett's warranty as an example... there might as well not be one
This is the reason I went with Per4manz, their warranty is, "All of our units are backed by a written Warranty for a period of 12 months, 20,000km, 500 hours for new units & 6 months, 10,000km 250 hours for reconditioned units."
4 years old, 28psi, and still going strong. Gotta love it!
^ ye no.
It would still be a conditional warranty, same as Garrett's.
There is no way it would be open ended, there would be more too it
The only thing Grant stipulated with mine was that I was not to exceed the maximum boost level of the unit.
im guessing you have had past experience with .63 housing and internal gate then. if i get a real 35r then it will be .63 housing as i want a really responsive set-up unlike making a cup of tea whilst waiting for it to reach boost threshhold lol. engine 26/30, should be on pretty early hopefully 3200rpm.
but yea, this turbo wasn't too sure about hence the topic. if you have any past history would be very keen to hear about it.
cheers
cheers
why not get a .82 3076R. why get a 3582R and put such a tiny housing on it?
You should go and read the full version :)
How is there a maximum boost level anyhow, every motor is different therefore moving efficiencies across the map
cheers
Not personally - but the sheer amount of users posting info is all i need.
I toyed with the smaller frame GT30, T04e etc on various motors.
If you want responsive and its on a 26/30, you are kidding yourself to run a .63 :)
Get a smaller turbo comp wheel if you want response, not a smaller rear housing (in this instance)... more reading the RB30 hybrid dyno thread :)
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
    • Hi. a little later but if the topic is here. So...the exhaust is the same and you can use 25/Turbo or any aftermarket? What about intake side? Is it too "plug n play" or? (i do not remember for 100% but i think that one intake to head gasket was little bit different than on the RB25 - i bought gasket kit way back) I know that even if it "plug" those butterfly swirls would cause ECU to be confused or?   Just asking for the info 🙂 and of course the RB25 things are easier to come by
