Nitto Rb Series Oil Pumps
Swiper the Fox
 Share
I have access to 5 Nitto oil pumps for RB engines. These pumps are individually assembled, set-up and tested. They use the latest generation world class materials.
Pumps are being sourced locally through Croydon Racing Developments and are now used in all of their big engines.
price is $1250 delivered. This is a huge saving over the comparable Japanese items.
please register below.
Paul, please confirm the start and finish date for this group buy, as well as the name of the business supplying the pumps.
Thanks.
look at the above post it clearly states CRD are the supplier. Lets say group buy is open for 8 weeks from date of original post. :P
Do you have any more info about them?
//Peter
RB SERIES HIGH VOLUME OIL PUMP
The NITTO RB series high volume oil pump is a high quality and performance aftermarket oil pump that will suit Nissan RB20, RB25, RB26 and RB30 engines. Oil flow and pressure is dramatically increased over that of the factory oil pump which is critical in modified engines for reliability of the lubrication system. Failure of this system is the “achilles heel” of the Nissan RB series engine even on lightly tuned examples and accounts for a high percentage of engine failures.
Factory and factory based oil pumps are highly prone to oil pump gear failure in modified engines due to the quality of the cheaper mass produced material used for the manufacture of the gears. Oil pump gear failure will result in indefinite engine damage. For this reason EN26 ball bearing steel is utilised for the manufacture of NITTO RB series high volume oil pump gears which are superior in strength and durability to that of both factory and its competitor’s oil pump gears.
NITTO RB series oil pumps are supplied pre-inspected, blue printed, assembled and cleaned to enable direct installation strait onto your engine and assure total confidence.
Detailed list of components:
Gears:
Material: EN26 ball bearing steel
Housing:
Quality alloy casting
Technical Specification:
Pressure relief valve crack off (dual springs): 120 psi *
Pressure relief valve crack off (outer spring only): 75 psi *
FLOW (LITRES / MIN)
ENGINE RPM
FACTORY OIL PUMP
NITTO HIGH VOLUME OIL PUMP
750
4.6
6.5
2200
15.3
20.2
7000
46.5
64.8
  • 4 weeks later...
Guest
 Share
