Nitto Rb Series Oil Pumps
Swiper the Fox
 Share
I have access to 5 Nitto oil pumps for RB engines. These pumps are individually assembled, set-up and tested. They use the latest generation world class materials.
Pumps are being sourced locally through Croydon Racing Developments and are now used in all of their big engines.
price is $1250 delivered. This is a huge saving over the comparable Japanese items.
please register below.
Paul, please confirm the start and finish date for this group buy, as well as the name of the business supplying the pumps.
Thanks.
look at the above post it clearly states CRD are the supplier. Lets say group buy is open for 8 weeks from date of original post. :P
Do you have any more info about them?
//Peter
RB SERIES HIGH VOLUME OIL PUMP
The NITTO RB series high volume oil pump is a high quality and performance aftermarket oil pump that will suit Nissan RB20, RB25, RB26 and RB30 engines. Oil flow and pressure is dramatically increased over that of the factory oil pump which is critical in modified engines for reliability of the lubrication system. Failure of this system is the “achilles heel” of the Nissan RB series engine even on lightly tuned examples and accounts for a high percentage of engine failures.
Factory and factory based oil pumps are highly prone to oil pump gear failure in modified engines due to the quality of the cheaper mass produced material used for the manufacture of the gears. Oil pump gear failure will result in indefinite engine damage. For this reason EN26 ball bearing steel is utilised for the manufacture of NITTO RB series high volume oil pump gears which are superior in strength and durability to that of both factory and its competitor’s oil pump gears.
NITTO RB series oil pumps are supplied pre-inspected, blue printed, assembled and cleaned to enable direct installation strait onto your engine and assure total confidence.
Detailed list of components:
Gears:
Material: EN26 ball bearing steel
Housing:
Quality alloy casting
Technical Specification:
Pressure relief valve crack off (dual springs): 120 psi *
Pressure relief valve crack off (outer spring only): 75 psi *
FLOW (LITRES / MIN)
ENGINE RPM
FACTORY OIL PUMP
NITTO HIGH VOLUME OIL PUMP
750
4.6
6.5
2200
15.3
20.2
7000
46.5
64.8
  • 4 weeks later...
 Share
    • Unless there's something particular about the Greddy manifold's injector holes that I'm not aware of, those injetcors look to be totally wrong. They would absolutely want to be spaced up to get those long snouts out of the runner. Which, I think, is not usually the way that that problem is solved. I think the problem is solved by using the correct injectors, which would be much more like what Andrew posted.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • EMJ33 or EJM33 - west end
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
