I know the "service manual" question has been covered before more than once, but before I go buying any off the internet, do any of these manuals have chassis alignment diagrams in them?
I've got some vibration somewhere above 60, and the car was sold stupidly cheap to the guy that sold it to me, so I've got a bad feeling about it.
On top of that, anyone know if there is anywhere I can check to see if the car has been "structurally" written off by any insurance companies? Can I ring the DPI and check for that kind of info ??
Even if there are diagrams out there in Japanese, that'll do, numbers are easy to translate.
Anyone?
Cheers
-Nic
https://www.sau.com.au/forums/topic/274136-a31-bodychassis-allignment/
weeell theres a number of different things like looking along the chassis rail looking for welds, especially round the front end of the car incase its had a front cut welded on, also like mine check in the front wheel arches to check for any irregularities like if its twisted out shape, also check to see if the area under the battery or area under the where the air box goes is twisted or bent, and then you can pretty much do the same in the boot, just pull up the floor covering and check it out for signs of being pushed outa shape
Havent looked during daylight, but it all appears ok under the work light.
VIN number is still on the car, so good sign....I guess.
The front suspension is low and stiff (cant fit 2 fingers between wheel and fender), the rear is...well, stock height if I ever saw it, and pretty loose, factory or slightly lower I guess, can't really tell if its uneven on one side, but the car drives pretty straight, doesnt sway away unless the diff is skipping, and even then, it co-operates.
Sound isnt audible at -60, havent tested it at 80-100+ yet, dont fancy pushing my luck that far with the thing until it's properly rego'd.
Sounds like that thunder sound when you're driving with the sunroof open all the way back, but since resealing all the doors and making sure the sunroof is closed, the sound is still present.
Will jack it up and have a look for any welds/ghetto repair attempts
Cheers Dude
maybe, if it hasnt got coilovers in it, then it might have cut springs in it, but yeah i got that thunder noise when mine wasnt crashed haha, it was air escaping through the front passenger door coz the door wasnt sealing at the top along the door rubber, and any air entering through the air vents escaped through that door so if you take it out for a drive soon check that. I blame a crash previous to me owning it that caused that
What colour is it..... and who did you buy it off of?
sounds like my old car......
and I will be able to answer most of your questions.
still VERY pissed off I let go of this car....it was a weapon and I let it go....but SHIT HAPPENS I spose.
send me a message buddy
Got it from Queensland, and no paint at the moment.
The story of my car goes a little something like this:
Low KMs, so I would assume imported recently, rego'd in NSW in 2006, it ended up in QLD sometime, I found this link:
https://cars2.ebay.com.au/Nissan-Cefiro-Tur...emZ130300698767
(click no to the prompt to view page properly)
Althought it sold for $1500, that Seller has a bad rating for "didnt sell at listed price and relisted item at higher price" or something, so
i dont know how much it sold for, in those photo's, it appears the same condition as the photo's from the page I bought it from
http://cgi.ebay.com.au/Nissan-Cefiro-rb20-...%3A1%7C294%3A50
Although it is now listed as having a HD Clutch, and unlike the first sale, doesnt state that the car "starts first time", "just needs a service", but now has an exhaust leak. Car runs fine, the exhaust leak is throwing hot air right into the filter, so combustion is shithouse, but it runs, it struggles to start, almost like its cold or the battery isnt big enough, but yeah, starts and runs.
My compliance plate cert's an RB20DE and Auto, but its got a turbo and 5 speed, the first sale listed these. The conversion looks pretty clean and overall well done, but another problem Ive run into, need a new compliance plate, or bigger brakes to match the turbo 5 speed models to pass pits.
EDIT: First sale ended April 27, sold for lack of stage space
Second sale to me was on May 14, again, lack of stage, needed money for upcoming 30th and was moving house when I let him know the car arrived here in WA
Im hoping this car hasnt been thrashed too badly.
What do you guys reckon ?
I'm just about to go and check all the door seals I fitted the other night before I noticed the sound for the first time, hopefully my paranoia ends at that, will updated in a few hours.
-Nic
Edited by Nic_A31
Checked all the seals quickly and did some laps, the thunder sounds a little different, not as loud but a little more frequent, steering wheel is giving some feedback when driving, is kind of pulling a little bit, but usually not much unless the diff wants to jump around.
Guess its time to check wheel allignment + tire pressure, and if that atleast sort of helps, get my suspension out of the way first ??
Cefiro + Wet Roads = Awesome
It ended up being ONE orange plastic clip that holds the weather seal to the door, it was on the driver's door, just below the strut.
i've got one or two left over, but pretty sure Im missing a few more than just the two.
I suppose Nissan want $3.00 each for them ??
Know how that feels, I get the most annoying whistle through the exact same spot, know its at the top somewhere, but never actually looked into it. Wouldnt know where to start, or where to fix it really. Whole door looks to be different from the rest of the car. Guess whoever had it before me, never put it back on properly. :D
  • 1 month later...
I've taken some pictures tonight of the underside of my chassis and in need of some advice.
Can anybody PLEASE add me on MSN and I can show some pics ??
I'm pretty sure my Cef is f**ked, but just need some other views on it. Wheather or not it is actually completely f**ked, if its fixable, etc
[email protected]
i smashed my old ceffy, the front left chassis rail ended up kinked in the firewall. still drove fine, so dodgy rattles etc even though the front left corner was making the rest of the car crab...
put some pics up here.... i had many funny rattles when i first got it, could be any number of things...
oh yeah and my old ceffy doest exist, so your not in ownership of it.
Here's the worst looking one. Mainly the chassis rails go up and down, but dont soo much warp off path.
Judging by how quickly the rust has built up at the scratches, it is recent, and the seller claims no knowledge of it. Some shit on the con note for the vehicle freight differ from one end to the other, so I'll be having a chat to them, wouldnt suprise me if they took it for a thrash, floored it up and down the ramps, etc.
The panels are out lf line as well, the gap between panels will start at like 10mm at the top end at the bottom its down to 2-3.
This applies to front right, bonnet (right), rear left, boot (left side).
Yeah, I know, its a drift piggy, just weld it up and she'll be fine, but I'm way too much of a perfectionist to drive it knowing its like this.
In terms if the rails, they are straight and parrallel, its just the dents up and down I can see, and the panel alignment.
Another thing, that same vibration while driving is even heavier when its jacked up, alot of shaking, it kicks in at the same speed and since its not moving its own weight, the vibration gets worse alot quicker, to the point where I can't have the wheels doing over 50kmp/h without it trying to jump off the stands.
Somewhere in the drivetrain isnt bolted in properly, but where do I start?
Engine mounts look almost brand new, and seated properly (and doesnt move around even the slightest bit when revving up), havent checked the gearbox < tailshaft < diff < axles < wheels
I have seen the drive-shaft centre bushing go bad on a few. The bushing which has the drive-shaft passing through the centre comes loose around the edges where it comes into contact with the metal bracket.
I would check that first.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
