hey guys the cars making a good 400rwkw and is very much a show street car but mostly driven on weekends to shows and cruises. atm the cars main goal is going straight and not around corners as it was intended to be a street drag car. im currently running 19x10s on the car but am considering going down to 18s for the better choice of tyres.
i need some advice on who i may have to see and what sort of products i should look at.
coils are useless because they are so hard and ive heard much about 90/10 setups but how will this effect drive ability if i wanna go to the shops to pick up some milk.
any help much appreciated.
Edited by Jap_Muscle
https://www.sau.com.au/forums/topic/274165-street-car-400rwkw/
Have you considered turning the boost down when you're not on a dyno?
thats fine and all but when when im playing with the v8 boys or the fpv guys they are pretty much at the 360-400kw range....so although you have a point it sort of defeats the purpose.
hope that makes sense
Its alright mate, I UNDERSTAND.........................
Go for a set of S-Comps. Something with a treadwear between 100-200. An R-Compound tyre will need a significant amount of heat in order to work, and doing a burnout right before you street race some Commodore will probably be even worse. An S-Comp will come almost on to temperature with regular driving. They'll also last more than a few thousand kilometres on a normal car.
You should probably aim for a more drag radial, at least in the rear, if you're only interested in going in a straight line.
Nitto 555Rs are quite popular, and were designed as a road legal drag radial.
Mickey Thompson has a few street legal radials, but I can't find a treadwear rating on them.
Otherwise, go to any S-Comp. Even with stiffened sidewalls for cornering, the rubber compound and tread pattern will still give better grip than your average street tyre. Avoid Falken RT615s as I've found their grip woeful on my NA car. But other ones like Federal 595RS-R or Toyo R1Rs should be right up your alley.
The Toyo RA1s might also suit you, but with a treadwear of 40 they won't last too long.
Tempe Tyres advertises Nittos on their site.
Another option would be to use a boost controller that has a "Push to Pass" button to switch to another pre-set. You could run low boost in the first few gears to help you hook up (and around those pesky corners), and then hit the switch when you're on a roll to get your full fat 400rwkW.
GReddy offer a wheel mounted switch for their Profec B EBC:
or you can use this DIY to make your own.
Just watch out for dangers to manifolds.
Edited by scathing
Traction Tyres in rowville are highly recommended and widely used. I am pretty sure that is where Gary Cook would send you too.
I have also heard Quadrant in Berwick are good.
Techsport in Bayswater do SOME setups, they are DMS agents.
Racepace set up some nuts GTR's, for track and I am sure for street too.
Some people recommend Centreline in Thomastown
There is also GT suspension in Flemington
Centeline would be my top recommendation, talk to Chris or Glen, then Traction Tyres talk to Andrew.
There are lots of tricks you can use to increase the rear traction;
Tyres are always #1
Then spring rates, don't go too high, 165 lbs/inch is the standard rate and there is nothing wrong with that.
Height, don't run it too low, anything under 340 mm (centre of wheel to guard) is going to be a problem.
Camber, don't run too much negative camber, if you are only doing straight line stuff then 0.5 degrees positive is the go.
Toe, run a little toe in, around 2 mm per side is OK.
Subframe alignment, add some rear squat for weight transfer, a subframe alignment kit (pineapples) is a cheap and effective upgrade.
Cheers
Gary
thanks for that greg,
I'll have a chat to centreline and see what they think.
Do you think radial ryres are going to extreme for the street? How long will they last before bring useless?
Is it enough just to go radial on the rear or all 4?
Skyline drivetrains are pretty tough but can they candle 400kw with radial gyres. I'm a bit worried something might snap.
Anyone know what the 34 gtt can handle?
He is actually sort of correct :)
You go out trying to race on the street, on 'street drag' radials you'll eventually break stuff either way with big launches. Nothing lasts forever.
300-320rwkw with a correctly sized turbo... being you are 1. Lighter 2. Better geared diff wise 3. Would actually have proper traction on normal street tyres without resorting to street drags which you must be VERY careful with...
However being you will have 400rwkw means you'll have a big turbo... that also means that in all likelihoods - You are highly to be slower ;)
More power does not equal faster in terms of a street car.
To be dreadfully square, what you want to achieve borders on the impossible really.
I had 370rwkw, my car is faster with 280-300rwkw on the street. Simple as that.
Prepped Drag Strip in controlled conditions - different story of course.
For the record I've had terrible experiences with Centreline and GT Suspension, so i cannot recommend them
Im very very happy with TruTrack (Nth Melb) and Traction Tyres (Rowville), both have been exactly what i'd expect from a professional business.
the turbo isnt that big. its a gt35r with a .84 rear. its defiently a streetable turbo.
with a 3L bottom end i see full boost before 4000rpm. i highly doubt a 300kw car could be compared, especially 2.5L
my biggest concern (and i should have thought about it before i did the build) is drive train and gearboxes now.
i know GTRs are good for 500kws. how do the gtts fair?
is it more likely that diffs will snap or gearboxes?
everyone says that until they actually get out there.
I've played with 10 sec cars upto 110km/h - they have nothing and i was putting around with 260rwkw @ the time.
Traction is everything, something you wont have with 1400kg's and 400rwkw
gearbox should be fine.
well i guess your right. wont know for sure till its out on the road.
fingers crossed....
do you rekn the diff will be ok?
I 100% agree, I have a 650 bhp 2WD Skyline and a 450 bhp 2WD Skyline and there is absolutely no doubt that the 450 bhp one is faster on the street, no contest. My cars have the best suspension set up I can manage, with lots of sophistication in the geometry based on over 10 years of road and race Skylines. Plus I have 3 types of tyres at my disposal, a quality road set (Michelin Pilot Sport), a circuit set ("R" type in 2 compounds) and a drag set (of MT/ET Street rears) and untit I get onto a circuit or a drag strip the 450 bhp Skyline would be my choice.
Cheers
Gary
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
