R33 GTS-T SII 4 Pot Front Brake Calipers (Ceramic coated)
Comes with
ENDLESS Brake Rotors (Slotted) (Less than 1,000km)
ENDLESS CCR Brake Pads (0-800 degree) (Less than 1,000km)
Need an upgrade. Rotors and Pads are installed a few weeks back.
Selling $800.00
Edited by Tomei_Powered
https://www.sau.com.au/forums/topic/274204-r33-gts-brake-calipers-rotors-pads/
Hi.. Am upgrading my Stagea SII brakes and have been told to look for some R33 brakes as they bolt straight up. So.. am very interested.. Do you have any pictures??
Cheers.. :)
Comes with
Selling $800.00
Cheers.. :blink:
That is about 90% right. Will need to make bolt sleeves thru the front hubs and also need a small front barke line mod
Rear bolt up fine.
Front R34 calipers bolt straight on.
Have you done this upgrade to your Stagea?? Is it worth it?? Much performance increase. Am looking to do some track days and hoping for a decent upgrade however got qouted $4200 for new AP racing front calipers, rotors, and pads fitted, but no way can justify that amount of money on my brakes just for the odd track day here and there.. Maybe I should be lloking at R34 brakes then...
By the way, cheers for the info mate.. This site is awesome.. learning so much about my car and getting lots of helpful info from people on here..
Rear bolt up fine.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
