easy, take the rb25 knock sensors and screw them into the provisions on the rb30 block
Im pretty sure there weren't any spots for them on the 30 block. Just trying to find out if there is another way around it without tapping 2 new threads in the side of my block (I dont get the car back till saturday so I'll check the block again then. Thanks for the idea tho :) )
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4650955
My personal experience as with many others was that the knock sensors were a straight swap. As far as I know both S1 and S2 RB30 blocks have the same provisions for knock sensors as RB20, 25 and 26. If for some reason yours is does not have these you may have to do something custom :)
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4651436
Look again.
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4651529
Thanks heaps guys. I got the car back yesterday and pulled the inlet plenum off today. the spot for them on the rb20 is just below the head but on the 30 block the spot was there but they were not drilled at all, although there was holes drilled and tapped directly below the undrilled spots (if that makes any sense) im hoping it wont cause any problems having them half way down the block???
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4655806
Half way doen the block is fine - thats where mine are!! They do f**k all anyways.
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4662491
Mine work very well in that location, consistent results when compared to the knock amp and headphones.
Cheers
Gary
The factory ECU will not retard the timing if it sensors detonation. From what I have seen it will switch between high and low octane maps based on knock feedback at low rpm high load. If it changes from high to low and it still continues to detonate there is nothing it will do to stop it. So in a sense they do f**k all.
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4669900
I drilled and tapped the higher locations for my knock sensors, the thread pitch is 1/4 BPT by the way.
I run a PowerFC and rely very heavy on my knock sensors, so I wanted them to be as accurate as possible. Plus, it's very easy to drill, tap, and install.
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4673145
did you actually notice any diffrences by mounting them in the higher positions??
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4674733
I could almost guarantee you that any location on the intake side of the block will work to the degree thats required for the factory ecu or PFC.
I have played extensively with knock sensor location on EJ25 block as I was experiencing spurious knock at a particular load and rpm point and found that moving the location of the sensor didn't help at all. Subarus are much more particluar with knock snesitvity than most other cars as they learn both advance and retard ignition.
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4674933
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
