R33 Gts S1 Non Turbo
selling due to where i live is a training ground and i cant even drive my car to the shops without getting pulled up i love this car was going to fix everything on it but ive bought a new ute so i am open to swaps even for a turbo car i travel alot for work so it wont bother me if i have to get a work exemption permit.
car: 1993 (i think) r33 skyline s1 gts (non turbo)
has 143xxx on the clock purchased the car with 128xxx
motor:
stock apart from a bmc air filter and a canon
always run bosch ultra spark spark plugs which are changed every 10 000 oil is always changed every 4000 and filter.
driveline:
as i beleive it has a rb25det gearbox and an upgraded clutch i dont know what clutch as i bought the car with the clutch and it has a viscous lsd in it.
interior and cosmetics:
has 3 drift gauges water temp volts and air/fuel and a mini gizzmo shift light which are all wired up and running interior is largley stock apart from them will throw in an aftermarket wheel when car is bought, has a kenwood stereo clarion speakers in the front doors kenwood in the rear parcel shelf 12inch kenwood sub and a rampage amp, jsut recently i have installed a 8000k hid kit with led parkers. rear tail lights are spray tinted but are still visible and have never been asked about them
suspension:
tanabe sustec pro coilovers with hks castor tops in the front spring rates are 8 front and 6 rear firm ride.
bad points
needs a respray has humidity blisters on roof and drivers side rear quarter
new front guard as it has a dint which has been bashed out.
needs new castor rods.
some very mechanical minded idiot put brake fluid in the power steering doesnt hurt it jsut steerings heavy
needs a wheel allignment
window rubbers need bailey channel put in.
doesnt like to start bone cold but never stalls
this car has never let me down since i have owned it i did want to build it up but there is no point in doing it all and making it turbo becassue i feel it is eassier to buy a turbo car
price: ballpark figure of around 6-7k i bought the car for 5 completly stock and with no stereo or anything my loss your gain
no stupid figures from know it all cause you will be told get f@#ked if you ring and say 3 grand
i am very open to swaps with cash adjustment either way
ill post up pics, ill take some interior pics and the front guard and all the bad paint spots tomorrow
reason why i am being so honest is you dont want to think you are buying a brand new car i mean these cars are not new anymore so dont winge about the condition if you think im over priced or anything, the car is under a car cover 99% of the time
cheers
  • 1 month later...
 Share
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
