is the key way still fitted in the cam?
i had a cas snap on me when running without the front cover, pull the cap off the cas and check the shaft isnt broken, also check the condition of the disc inside.
have you found some one else with the same cas so you can test?
not sure, but everything looked intact.. used a torch to look in and i could see the locator
still no luck finding one to test with....
i was able to start the car after removing the cas earlier, but it died again after 4mins or so, idled perfectly and gave me false hope :blush: .. i saw on the pfc ignition timing peak of 49, not sure if thats relevant
i have read ppl state cas can be turned in either director to make the injectors click and spark plugs spark, however i was only able to get it going in only one direction and it wasnt consistent clicking with the no. of turns (not sure if its meant to be consistent)
Are you getting an RPM signal from the ECU through the hand controller while cranking?
If you have fuel pressure, injector pulse, coil packs firing and compression in the engine.....as long as the timing is correct then it will start.
Try checking timing with a timing light while cranking to see what it comes up as
im only getting RPM signal on PFC controller intermittently, its when I do see it, im able to get it to startup on occassions, otherwise 95% of the time, no RPM action
  • 1 month later...
im having a similar issue to DRFT33
when i crank the engine normlly it wont start
but if i turn the cas prior to cranking it starts and runs.
also if i let it sit idling for a while then turn it off. most times it will start up again without removing the cas.
car is an r32 gts-4 with an rb25neo
what could be the problem?
  • 4 months later...
Hi
long time reader, first post :P, old thread bump but here goes...
I have exactly the same issue with my rb30/26
cranking the cas manually arcs my plugs out and spark is visible and you can smell fuel.
tried all the things that BWRGTR tried and more. had the timing cover off, comp test tried everything but the cas + afm
takin the afm out of my mates pathfinder makes it stall instantly and doesnt turn over, seems like a similar noise to the skyline when it tried to turn.
but apparently it sohuld start without the maf plugged in?
been workin on it non stop for 4 days seriously at the end of the rope lol
could it be the starter?
any input or ideas would be great cuz me and the boys are completely stumped.
Edited by pedl0r
    • Cheapest option, find a NEO head. Put in good springs, decent cams, and send it to the moon. I rev mine to 8600RPM, gets me about 232km/h down the main straight at SMSP bouncing off the limiter in 4th. I've never dared to grab 5th 🥲
    • Gday mate, Personally in my car i run 450kw in an s2 rb25 so also hydraulic lifters and have always run it to 7500 RPM and using some baby 256 poncams with new but stock springs and retainers. While i cant speak on any experience with solid lifters i personally have had no issues with my hydraulic lifters which were just cleaned and set in an oil bath before assembly over 7 years ago. Over 8k RPM is cool IMO and if you are using the stock gearbox or just a box with longer ratios the higher rpm certainly could aid to maintain boost into the next gear as that was always something i struggled with as i have a 3582r also but a hypergear equivalent could aid that issue. In summary i would make a choice on the cam you want to use first then decide which springs and retainers work best with it and then you can toss up if you really need the solid lifters, if the car is mainly street i would learn towards keeping the hydraulic lifters as when installed properly and nothing too hektik going on around them they do the trick.
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
