Hey people got a few parts to sell, prices pretty firm as they are cheap.
Got three z32 80mm afm's, good for upgrades, excellent condtion mesh on both sides, $210 posted express each with plug (approx 6-7cm) cheaper if you buy 2 or all 3
Pioneer DEH-2050MPG and Sony Xplod CDX-GT250S, both excellent conditon with remotes and wiring, plays mp3/wma's, pioneer is in box used for 6 months and receipt probably under warrenty $100 for both!!!
K&N panel filter, less than 1000km old, Paid $85 selling $40
PM me or msg me on 0423284832. thanks Jesse
Edited by SUSS_13
Hi mate, are you welling to separate the Z32's? How much for just one posted to Melbourne?
Please let me know.
Cheers,
Kevin
  • 3 weeks later...
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
