Item: R33 GTS-T 5SPD TURBO!!! has done 105,000km
Website:
Item Condition: Good
Reason for Selling: No time to drive it
Price and Payment Conditions: 12k ono!
Extra Info: heres wats done.. alloy radiator. veilside catback exhaust. nismo lip on boot. k&n pod. top secret front bar. chrome headlights. trust steering wheel ( 330mm i think.. its pretty small anyway). aftermarket gearknob. boost tee running 11pound all day everyday.. no blow by wat so ever. car was previously owned by a japanese mechanic who had all the belts done and new coilpacks done and serviced b4 he sold it to me. car has been driven twice since i have owned it.. car is 100% ready for roadworthy but will be sold without and is not registered.
Pictures: can email some or look on boost there is a pic..
Contact Details: dean. pm or 0403423121
https://www.sau.com.au/forums/topic/274335-item-r33-gts-t-5spd-turbo-105000km/
:D PRICE DROP $10k NO OFFERS! PRICE IS NOT NEG! not in a rush to sell anymore so its 10k till august. if it doesnt sell ill just keep it :thumbsup:
Edited by Deano_Drifter
Hey where are you?
has car been garaged?
anything replaced?
hows clutch? how does the car idle?
i'm interested, thanks.
im on the gold coast. yes car has been locked away in my shed kept very clean. info on car is stated above. car idles and runs perfect.
  • 3 weeks later...
  • 3 weeks later...
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
