hey guys.. i just brought a manual boost controller and installed into my r32, one hose is coming from the wastegate to the boost controller then the other hose comes from the turbo. is that right? cause when i brought the car there was 2 hoses already there but they were connected.
when it hit boosts then the car started jerking. it sounds like its hitting the a limiter. but i dont know wats going on? can anyone help :)
thanks guys
thanks guys
Sounds like you are hitting boost cut which would mean it is more than likely not hooked up correctly. Have you made sure the boost controller is turned right down?
Also have you got the hoses round the right way? does it have an arrow or some indication on which hose should go to wastegate?
Also usually the other hose needs to pick up manifold pressure but you say it is hooked to turbo can you be more specific?
Also what type of boost controller do you have?
In most cases there will be an arrow on the tee, make sure this side points to the wastegate.
Secondly, you've got the boost wound up too high and it's hitting the boost cutout. Make sure you screw the adjuster all the way in so that if you were to blow into it, no air would escape the opposite side. Then perform your road test and wind the adjuster out in small increments until the desired boost level is achieved.
As above, make sure its around the right way, if you don't, the actuator wont see any signal = lots of boost, boost cut and eventual FAIL.
Oh, and even if you don't do it for anything else. READ THE INSTRUCTIONS for this one.
Edited by Yeedogga
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
