Thanks Joolz/Andy :D
Andy,
Hehehe the coastal roundabout cruises are always good value :D
Yeah mate I'm hanging to get out to AIR again :uh-huh: especially with the new night time "real street car" format. I remember way back having a big chat with Anna about running a Wednesday night "street car" summer format - & whaddaya know!
Congrat's on the 12.7 too mate. The S15 is a such a great little package. Near enough to 200rwkw, easy 12's & 1.8 60's all on the stock turbo & street rubber.
The LS1 lads are starting to runs some solid times now too! Henry into the 12's NA & Rob (Blue SC CV8 Munro) with 11.8
Thanks :D .... and I know there's more in her yet, when I get my EBC in and then learn how to drive. I am aiming for the December Wednesday night meet (as I want to get quite a few things sorted before then), so I kinda hope you don't get your beast back before then - or if you do to come out in Dec as well!
Originally posted by hippy
anyways did u get a divorce matt??  is that why u keeping the car??  LOL  :D
Haha naa mate all is well on the home front, better than ever in fact :) I'm getting a promotion @ work plus a bit of a lump sum so we get to buy the house & I get to keep the cars :D
Good to hear Matt, ill never get the chance to line up next to you:(
Youll have to take me for a spin when you get her up and running
Remember if you do decide to sell im looking:)
Andy,
My pistons have arrived FINALLY! So I'd say the car will be back on the road, run in & the injector/exhaust mods done ready for the Dec meet :)
Erica,
Thank dudette. Yeah the little one is just the best thing ever ;) And guess what her fav toys are... ? CARS! :uh-huh: :cheers: Phew indeed!
Matt,
I really hope things are working out ok for you re the car situation mate. Shitty thing to happen to you & I know what it feels like :wave:
Yep no prob's you can come for a spin anytime :)
I'm not selling unless I REALLY have to but you'll be the first to know.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
