The Anything And Everything Sale
Hi all,
I have for sale:
Apexi front pipes for R32/R33 GTR (Off the dumps measure 2.25', at the cat measures 2.75', fitting has been attatched previously for oxygen sensor) $300
Nismo clutch pedal bracket to suit R33 GTSt, brand new $180
Nismo FPR to suit RB and SR setups, brand new $160
Tomei metal exhaust manifold gasket, brand new $80
N1 Oil pump gears, brand new $300
R33 GTR recirculation piping $120
GTR BOVs with mounting brackets $200
RB25 head (including cam, timing and valley covers) minus CAS $550
RB25 block, crank and crank cradle (number 6 piston blew a ringland) $150
R33 GTSt calipers, rotors and pads $550
R33 GTSt climate control unit $50
R33 GTSt diff (non abs) $200
R33 GTSt driveshafts (pair) $50
R33 GTSt front and rear sway bars $20
R33 GTSt condenser $50
R33 GTSt HICAS unit $50
Earls Oil cooler and relocator kit with braided lines to suit RB setup $500
Hawk brake pads for R33 GTSt, brand new. Front $100, Rear $80, Pair $150
HKS BOVs for RB26 $50
Motul RBF 600 brake fluid $15
B&M Oil cooler cores, brand new. Each $120, Pair $200
Stock R33 GTSt flywheel (will require machining) $50
Cooling Pro 40mm radiator to suit R33 GTSt/GTR, brand new $250
Parts are welcome to inspection.
Prices are negotiable to a degree.
I am located in Sydney, I am happy to post interstate at buyers expense.
  • Replies 47
Hi all,
I have for sale:
will you sell the hawk pads for 150 delievered to perth.
 Share
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
