Hi all,
I have for sale:
Apexi front pipes for R32/R33 GTR (Off the dumps measure 2.25', at the cat measures 2.75', fitting has been attatched previously for oxygen sensor) $300
Nismo clutch pedal bracket to suit R33 GTSt, brand new $180
Nismo FPR to suit RB and SR setups, brand new $160
Tomei metal exhaust manifold gasket, brand new $80
N1 Oil pump gears, brand new $300
R33 GTR recirculation piping $120
GTR BOVs with mounting brackets $200
RB25 head (including cam, timing and valley covers) minus CAS $550
RB25 block, crank and crank cradle (number 6 piston blew a ringland) $150
R33 GTSt calipers, rotors and pads $550
R33 GTSt climate control unit $50
R33 GTSt diff (non abs) $200
R33 GTSt driveshafts (pair) $50
R33 GTSt front and rear sway bars $20
R33 GTSt condenser $50
R33 GTSt HICAS unit $50
Earls Oil cooler and relocator kit with braided lines to suit RB setup $500
Hawk brake pads for R33 GTSt, brand new. Front $100, Rear $80, Pair $150
HKS BOVs for RB26 $50
Motul RBF 600 brake fluid $15
B&M Oil cooler cores, brand new. Each $120, Pair $200
Stock R33 GTSt flywheel (will require machining) $50
Cooling Pro 40mm radiator to suit R33 GTSt/GTR, brand new $250
Parts are welcome to inspection.
Prices are negotiable to a degree.
I am located in Sydney, I am happy to post interstate at buyers expense.
https://www.sau.com.au/forums/topic/274379-the-anything-and-everything-sale/
  • Replies 47
Hi all,
I have for sale:
will you sell the hawk pads for 150 delievered to perth.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
