Just to jump on the band wagon: What a freakin' awesome day!
A massive thank you to everyone involved in the organising and running of the day!!
All of the photos & videos are great (even if i am not in many) !!!
I was lucky enough to be able to drive home without any issues (would be a long walk back to Canberra)
Can't wait till the next one....
  • Replies 215
So pissed didnt take u out in the failvia George!! Next time for sure!
But yes all i cam say that wiggles MX5 is an absolute blast to drive! I cant wait for the next opportunity to play swapsies with Chubbeh!! :dry:
Currently trying to see if i can figure out this whole upload to you tube thing/... if i succeed i will post some vids :domokun:
yeah sure you are... I know u don't want me to experience it on a track...I was never game enough to take it out before I sold it to ya and now you're just teasing me with it and making me suffer, LOL ... :) only kidding ..
It's ok, I'm first in line for a ride next time .
HEY, BTW, thanks to both you and Chris for letting me borrow the tools, etc...i'll be better prepared next time.
Thanks for uploading sean; shows you slaughtering my gts-t on the straight at 9:05... I might have held you off if i wasn't held up through all the twisties :banana:
That's a pretty quick 32 you got there though!!
I wish I had semi's on the 18's now!!, and better brakes.
farkk you complains alot!!
You know it.
$$$$$ later and you would too! :P Home built engine still going strong thank god.
Nah, great day and everyone had fun pretty much.
really bad quality video of session 1, and my first off.
Wow I only ever heard yours as you overtook me each time, sounds wicked from trackside.
lol at my little thing cracking and popping the whole way down the main straight as I roll into turn 1.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
