i am cleaning out the shed, if i find more parts lying around i will list them here.
Rb20det- $200, i bought this engine 3 years ago to rebuild, when i got it the head was seperated from the block due to a blown head gasket, it has no turbo, wiring, ecu, altenator, aircon pump or power steering pump. the engine is now completly in pieces, and has been stored in cardboard boxes for the last few years.
R33 S2 doors- $200 pair
standard R33 front struts- $80 pair
standard R33 front sway bar- $50
R33 S2 front guards with indicators- $200 pair
R32 front guards- $120 pair
R33 glovebox- $40
R33 aircon/fan/heater box- $50 ea
R33 steering column- $50
r33 S2 rear quater interior trim- $100 pair
r32 rear quater interior trim- $50 pair
R33 S2 door trims- $150 pair
R32 fmic with pipe kit- $150
R33 front hubs- $100 pair
full set R33 seat belts- $150
R32 side mirrors- $100 pair
R32 glovebox- $40
R32 indicator stalk- $30
R32 bonnet hinges- $40
All prices are neg.
I can post smaller parts at buyers expense.
bigger items are pick up only from Woodville, nsw, 2321-10mins from maitland.
https://www.sau.com.au/forums/topic/274459-r33-s2-r32-parts/
wot sort of condition are these in?? are these upper trims??
they are the lower trims, each side of the rear seat, excellent condition
What colour & condition are these in?
passenger side has a small scrape, will need minor repair, drivers side is good, they are black
i also have a r32 rear subframe, it is complete minus diff and calipers. $300 ono or pm me for individual part prices.
R32 manual conversion parts-no gearbox or tail shaft, $150 ono
my number is 0411553427
Thanks,
Brock
hey bro what colour are the front panels and if i buy most of this stuff how much off each item are you willing to drop off it. Cause i only really need silver fron right and door right panels.
hit me back
What colour are you r33 S2 doors in? im after the passenger door.
hi mate,
doors are white
send me your email address if you want pics.
Hey mate do you have the drivers side seatbelt available?
Cheers
pm sent
i have decided to sell the engine in seperate pieces.
everything is there,
crank, rods, pistons, cam shafts, cam gears, lifters, injectors, manifolds, sump, block, head with valves, there is a altenator and air con compressor, standard intercooler pipe with BOV. COMPLETE engine in pieces.
i can post anything under 20kg's at buyers expense
pm me.
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
