Hey everyone
i was looking into some clutches because mine has a bit off slip in it. I’m pretty sure its the clutch.. ill give you guys a quick scenario so then people can let me know defiantly if it sounds like the clutch is slipping.. For example if I’m at the light i have to take the clutch out a bit and then it doesn’t grip until the last moment and then grips…that’s the same as say I’m going around 60km/h in 3rd and then accelerate it doesn’t pull hard as it use to.
At the moment it has a heavy duty clutch but I’m not too sure what brand/model it is as it came with the car when i brought it.. at the moment I’ve got approx. 250 rwhp.. The question is what does every one think about the exedy 7056hdb (Heavy Duty Button Kit) clutch? i looked on the website and couldn’t find the rb20det engine under r32, so i rang up a local car shop and they gave me that part number..
I don’t mind if its heavy that’s cool, another question i had was would it put to much pressure on the stock rb20det gearbox?
Also another part that might be worth mentioning is that I do like to take it on the track once a month or so.
Besides that it’s just a Nissan skyline R32 gts-t with the rb20det and stated before has a stock manual box.
Thanks guys any help/input appreciated.. if any one is also using this clutch please feel free to let me know what you think off it.
Niran
https://www.sau.com.au/forums/topic/274460-exedy-7056hdb/
    • Everyone wants an ECU they can plug onto their engine, modified or not, and put of the box it just runs perfectly like a brand new modern engine straight off the production line. Too many people just don't understand things like the base maps are as you said, just to give a starting point, and then you need to spend time getting it right for your vehicle.   I wonder if the people wanting it are the same ones who'll just buy a chip for a "stage 2 tune" online and then wonder why their engine blew up...
    • Quite possible! And well worth checking out, as it will be more durable than paint
    • Good point, I think you can get black ceramic coating as well, so that could be two birds with one stone
    • If I was you I would fix them up, as far as I know the 400R bumper is unobtainable now, the rear bumper and side skirts cost a fortune. The look of the car with that body kit on is awesome! Subtle but aggressive looking, how long have you owned her and done much in the way of modifications?
    • More so heat management so you don't melt stuff around the turbo, especially if you decide to hit the track.
